I had bought a Adafruit 0.56" 4-Digit 7-Segment Display w/I2C Backpack - Green, part number 880 and the second digit is not working properly.
Connections are ok and the sketch used is from Adafruit LED backpack library with no changes.
I tested the code + wires etc with an other display and everything works as it should.
Please see attached files for more.
Order number is : 2503775-9897330286
Part number is : 880
Thanks in advance
- GRB_com
- Screenshot_20220119-125640_Gallery.jpg (31.37 KiB) Viewed 118 times
- 20220117_152610.jpg (492.15 KiB) Viewed 118 times
- Slack Image (2022-01-19_10-24-59-245).jpg (62.19 KiB) Viewed 118 times
- dastels
Re: Adafruit 0.56" 4-Digit 7-Segment Display w/I2C Backpack
My first step would be to go over all the soldering you did ... just touching the iron to them to remelt/reflow the solder. In my experience that will often do the job.
- GRB_com
Thanks for the fast response, i just finished re-soldering all pins but the problem remains the same , second digit has the same issue.dastels wrote:My first step would be to go over all the soldering you did ... just touching the iron to them to remelt/reflow the solder. In my experience that will often do the job.
Thanks in advace
- dastels
It would seem to be a bad chip then.
Please email [email protected] with a link to this thread, your order number, and request the replacement of one Adafruit 0.56" 4-Digit 7-Segment Display w/ I2C Backpack - Green - STEMMA QT / qwiic.
- GRB_com
Thanks a lot, i will follow your instructions.dastels wrote:It would seem to be a bad chip then.
Have a nice day
