Will Raspberry Pi Pico work with Quad Alphanumeric Display?
JPJ
Post by JPJ »
I've been successfully driving the 7 Segment Display with Raspberry Pi Pico and backpack, but tried the alpha4numeric today https://www.adafruit.com/product/1912 and it works perfectly from an Arduino Uno but garbage is displayed when used with the Pico. Exact same code on both. Photos follow. I checked and have the latest library releases for Adafruit_GFX and Adafruit_LEDBackpack. Thanks!
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Adafruit_LEDBackpack.h"
Adafruit_AlphaNum4 alpha4 = Adafruit_AlphaNum4();
void setup()
  alpha4.begin(0x70);
  alpha4.writeDigitAscii(0, 'A');
  alpha4.writeDigitAscii(1, 'B');
  alpha4.writeDigitAscii(2, 'C');
  alpha4.writeDigitAscii(3, 'D');
  alpha4.writeDisplay();
void loop()
  delay(500);                       // wait for a second
adafruit_support_carter
Re: Will Raspberry Pi Pico work with Quad Alphanumeric Displ
Try moving this pin to 3V3 OUT instead of VBUS:
JPJ
Post by JPJ »
Thanks for the reply and suggestion. Unfortunately same exact results as shown in first photo I attached above, meaning same exact LED elements illuminated.
JPJ
Post by JPJ »
p.s. I also have a RED Alphanumeric display, same exact results.
Something does seem up with that combo. I've recreated this and opened a new issue for it here:
https://github.com/adafruit/Adafruit_LE ... /issues/68
JPJ
Post by JPJ »
Thank you! I very much appreciate your support!
Regards,
JpJ
JPJ
Post by JPJ »
RESOLVED
Update Earle Philhower's Ardinuo Pico Board library to 1.19.5 and tested. Characters display normally as expected now.
Thank you!
Cool. Glad that fixed it. Thanks for letting us know. Have fun!
