Dear Adafruit, This little board ( https://www.adafruit.com/product/1571 ) is GREAT! But it's "discontinued!" However, you still sell this 3.5 breakout ( https://www.adafruit.com/product/2050 ) and I just bought one for a project. After spending at least 6 hours trying to orient rsisitive x/y touch with A2 and A3 inputs, I gave up and headed down to my huge parts bins searching for the ONE stpme610 board I knew I had leftover from a 5 year old project . It took two hours of searching, but I finally found my little old adaproduce 610 board! I downloaded the most recent version of https://github.com/adafruit/Adafruit_STMPE610. I hooked the old 610 up to my teensy 3.6 and did a tiny bit of code mod to the featherwing button example and VOILA!!!! A perfectly functioning x/y tft 3.5" breakout touch using SDA SCL! :) :) :) :) !!!
So I ask that, even though this can all be found on the feather 3.5" tft, you would reconsider the 'discontinuation' the 610 because I'm sure that like me, there are many out there who can use your 3.5 breakout TFT and this touch sensor, as well as the 610 code you provided.....
Thank you!
XRAD
XRAD's upcomming GPS tracker with TFT touch display, SD read/write mapping, and map scaling
XRAD'S Bring back STMPE610 breakout!!
