I've purchased the Adafruit Grayscale 1.5" 128x128 OLED Display (https://learn.adafruit.com/adafruit-gra ... y/overview) and the ssd1327_test Arduino program (https://github.com/adafruit/Adafruit_SS ... st.ino#L31) won't function correctly.
I'm using an Arduino Nano 33 BLE and connected the following pins up:
3.3V -> Vin
GND -> GND
Clk -> SCL (A5)
Data -> SDA (A4)
Do you have an idea as to why this OLED display won't function correctly?
- blnkjns
Re: Adafruit Grayscale 1.5" 128x128 OLED Display
My first thought was use hardware I2C pins, not A4/A5 as those are UNO pins, put apparantly the BLE uses that weird combo as well.
My second thought is that it has to do with the board library. What NRF52 board library do you use?
It is this board?
It is this board?
- adafruit_support_carter
It's most likely a connection issue. It could be incorrect pins, either being used or being specified in code. Or it could be mechanical, like soldering.
Try an I2C scan to see if the OLED address can be seen:
https://learn.adafruit.com/scanning-i2c ... es/arduino
If that still does not work, please post a photo of your setup showing how everything is connected.
