Order: 2837069-8884096101
Date: 2022-04-29
PID: 2423 (PiTFT Plus 320x240 2.8" TFT + Capacitive Touchscreen)
Hello, I recently received a PiTFT display I had intended to use with a cyberdeck & Pi 400 setup. I found and followed the instructions at https://learn.adafruit.com/adafruit-pit ... -install-2
Unfortunately, I am only getting a white screen. I have tried this with the Pi 400 + cyberdeck, then directly on a Pi 4, with a couple of different recommended Raspbian builds - all to no avail.
Is this definitely faulty? Is there something else I should be doing?
I appreciate any help or information, thank you!
Photos:
*edit: forgot order details!
PiTFT 2.8 inch Capacitive - White screen?
- mikeysklar
Re: PiTFT 2.8 inch Capacitive - White screen?
We can swap out the display if it does not look like a configuration issue.
Did you using the Pi OS Lite 2021-05-28 (recommended build)?
When running the installer script have you tried:
Which would be a good test to see if your model display can get into a usable console mode.
sudo python3 adafruit-pitft.py --display=28c --rotation=90 --install-type=console
