40 pin ttl rgb connector hold down clip TFP401
CWAlbert2
Post by CWAlbert2 »
Please help, I have 2 TFP401 boards of which I did break the little clip that holds the ribbon cable on the 20 cm cable to the board. Shame on me--of course. Can I prevail on your kindness to mail several of the clips to me; also, when inserting the ribbon cable into the connection, does the blue colored end point out or in?? Thanks and have a very good day.
mikeysklar
Re: 40 pin ttl rgb connector hold down clip TFP401
Post by mikeysklar »
There are a some 40-pin FPC parts you can scavenge clips from.
https://www.adafruit.com/?q=40-pin+fpc&sort=BestMatch
The extender might be the best deal with two clips on a $0.95 part.
https://www.adafruit.com/product/4523
thisisjampers
Post by thisisjampers »
What is the maximum cable thickness that this (4523) can accept?
mikeysklar
I've never seen a thickness number associated with FFC (Flexible Flat Cables) or FPC (Flexible Printed Circuit). Normally it is just length and pitch.
thisisjampers
I'm using a (custom) FPC. What thickness range is the part designed for?
mikeysklar
In believe .3mm thickness is the norm for FPC flat cables. On this particular part I don’t have a datasheet to reference for max thickness tolerance.
thisisjampers
What is the UL94 flammability rating of this part?
mikeysklar
There is not UL94 data for the FPC extender (#4523) or the TFP401 (#2218).
thisisjampers
Can you provide what plastic (including grade) is used? If so, the flammability rating can be looked up.
