5.0" 40 pin TFT Display > Problem
FrankL
Post by FrankL »
Hello!
I just purchased this display together with the RA8875 from a German dealer.
I connected everything to my Arduino Mega according to the information on your website (brilliant thing by the way) and ran the first test script.
Unfortunately, half of the screen is filled with vertical lines (see image).
Display problem
Display problem
So, I checked all wiring (including the 40 pin connection to the driver board) and repeated the tests - same result.
What am I doing wrong?
Kind regards
Frank
mikeysklar
Re: 5.0" 40 pin TFT Display > Problem
Post by mikeysklar »
Frank,
What is the Adafruit part# of the display you are using?
This is from the comments in the textmode.ino which I believe you are running.
The RA8875 is a TFT driver for up to 800x480 dotclock'd displays
It is tested to work with displays in the Adafruit shop. Other displays
may need timing adjustments and are not guanteed to work.
FrankL
Post by FrankL »
it is the 5.0" 40-pin TFT Display - 800x480 with Touchscreen from Adafruit, product ID 1596.
The problems also occurs when running the buildtest.ino.
KInd regards
Frank
adafruit2
Post by adafruit2 »
it looks like you're running the 4.3" example
FrankL
Post by FrankL »
Perfect - Problem solved, thanks! :-)
