DotStar Frequency
- PF61
DotStar Frequency
Is there a lowest clock frequency for DotStar? I'm experimenting with low frequency setups.
- mikeysklar
Re: DotStar Frequency
Dotstars are normally 20 KHz PWM while NeoPixels are 400-800 Hz.
Are you adjusting the Dotstar refresh rate by adjusting the SPI bus speed?
Just curious? What is your application that you wish to slow down the refresh rate?
- PF61
Thanks for the info!
I'm driving with logic, not an MCU. Debugging is easier at low clock speeds.
