Greetings.
Just hooked-up the 1.2" 7-Segment (yellow) and uploaded the sevenseg.ino to an original Uno per instructions.
It ran the demo beautifully! For about three minutes and then I noticed the high-speed timer freezing for a second or two, then a second or five, then it just quit.
I re-uploaded the sketch, no glow. I switched to another Uno, still no display.
I was powering the Uno from USB on a Mac Pro laptop, the display powered via the 5v pin on the Arduino per
https://learn.adafruit.com/adafruit-led ... -and-setup
...using the Classic example.
It was trucking along great on my work table here until I noticed number freezing, then catching up with the timing, then freezing, then nothing.
But now that the ambient light is reduced in my workroom, I notice three of the dots faintly illuminated. (see photo attached)
Thank You
1.2" 7-Segment w/ Backpack - Ran, Stuttered and Died
- MOOTZERONI
- 7-seg problem Lentz.jpg (622.49 KiB) Viewed 116 times
- MOOTZERONI
Re: 1.2" 7-Segment w/ Backpack - Ran, Stuttered and Died
(update) Seems to have been a bad socket on BOTH Arduinos. So disregard and I'll try to delete these posts now.
- adafruit_support_carter
One of the pins is not connected. The twisting of the wires together may not be providing adequate connection.
- MOOTZERONI
Yep... I think that was it. Back up and running. Thank you. This yellow is bright and beautiful!
- Davis2x1
mootzeroni,
What program did you run to test out your display. You mentioned sevenseg.ino.
Where can I find it. I am having a similar problem as I can't get mine to light up.
Thanks for your help, Dave
