ESP32-S2 TFT ESPHole
blakebr
Post by blakebr »
I just received my ESP32-S2 Feather TFT and tried to load ESPHole.
Double-click Rst. Loaded adafruit-circuitpython-adafruit_feather_esp32s2_tft-en_US-7.3.0-rc.0.
Loaded secrets.json. Double-click Rst. Loaded ESP_TFT_Hole.uf2.
hosts.txt shows as 147KB. So that would say to me that WiFi is connecting.
Putty console at COM27 shows only dots. The TFT display is blank.
What am I missing? Is there a CircuitPython test program I can run?
TIA,
Bruce
adafruit_support_carter
Re: ESP32-S2 TFT ESPHole
It sounds like bootloader mode is at least working. You were able to double click reset and see the BOOT folder to copy over the CircuitPython UF2.
Try going back into bootloader and copy over the factory reset UF2 firmware from here:
https://learn.adafruit.com/adafruit-esp ... -3107942-2
Also - check while still in bootloader mode, is there anything on the TFT?
