RGB Matrix + nrf52840 + RGB Matrix Wing: 15 FPS (very flicke
kwmcc
Post by kwmcc »
I've got this set up, the nrf52840 feather with the Matrix Wing (4A power supply), and a 64x32 RGB matrix.
The example code (both Circuit Python and Arduino) gives me about 15 FPS (as reported by the Arduino example code).
It's very difficult to look at. Definitely not what I expected, more like seizure inducing.
Any idea(s) what I could be doing wrong?
Here's a short video of what I'm seeing: https://youtu.be/Md4zOhkppbI (Hard to make a video of a flickering LED, the image is complete and not "rolling", but it is flickering)
mikeysklar
Re: RGB Matrix + nrf52840 + RGB Matrix Wing: 15 FPS (very fl
Post by mikeysklar »
Thanks for the video. I see what you mean that is difficult to look at.
Can you post a photo of any soldering you have done?
Also please link to the test program that you have been running. Would you prefer to pursue this through CircuitPython or Arduino? It will be confusing to do both.
kwmcc
Post by kwmcc »
The soldering photos are in a Google album: https://photos.app.goo.gl/77x7tpfc15MQq8JbA
The ino file is attached.
I'm cool working out the issues using the Arduino path, since that has the most fine grain control over what's going on.
Thank you!
[The extension ino has been deactivated and can no longer be displayed.]
kwmcc
Post by kwmcc »
One correction, the soldering pictures include the Feather Sense I tried as my second attempt.
I tried it using the "bluefruit sense" and a basic "bluefruit feather" (nRF52840). Both had identical results.
pburgess
Post by pburgess »
Taking a look now. The Protomatter library recently got some changes for ESP32…it’s possible something nRF-related was inadvertently broken. I’ll reply when I have some findings!
kwmcc
Post by kwmcc »
Thank you, appreciate the efforts!
pburgess
Post by pburgess »
Problem solved! Just published release 1.4.1…it may take an hour or two to percolate to the Arduino Library Manager.
kwmcc
Post by kwmcc »
That worked! Rock solid, no flicker. It's showing over 190 FPS with the demo code.
Thank you again! Really appreciate it!
