7 inch 40-pin display multitouch support
Zestyy
Post by Zestyy »
I'm looking at this screen (https://www.adafruit.com/product/2354) and controller (https://www.adafruit.com/product/1590) combo, And everything I need for my project it has, apart from the fact that I can't tell if it supports multitouch. I can see in the library that you can read if the screen is touched at a point, which seems like it is built to support multitouch:
  /* Touch screen */
  void touchEnable(boolean on);
  boolean touched(void);
  boolean touchRead(uint16_t *x, uint16_t *y);
But then I can't see anything that shows multitouch used, as the guide shows using a board which converts the touches to a mouse, which only needs 1 point.
TL;DR: Basically I just need to know if this screen supports multitouch, and if so the board that is best used since the recommended touch driver is now discontinued (https://www.adafruit.com/product/1571).
Thank you!
adafruit_support_mike
Re: 7 inch 40-pin display multitouch support
No, that display doesn't support multitouch. It has a resistive encoder, which will only get confused by multiple points of contact.
DJDevon3
Post by DJDevon3 »
Depends on what platform you want to use? Arduino? Circuit Python? Raspbian?
FoamyGuy is working on a Crestron tablet in his live stream running Circuit Python that has early alpha beginnings of multi-touch. It's probably an expensive project but has the features you're looking for.
https://youtu.be/-uCbbnEWAcc?t=1699 By the end of this deep dive, he codes in multi-touch support for the board in DisplayIO.
If you're going for a large 40-pin multi-touch display for Circuit Python you really want to pair it with a high performance board like the ESP32-S3 feather (with external 40 pin driver board module). The ESP32-S3 is currently one of the most powerful boards for Circuit Python that has Wifi and Bluetooth. Though you could also go with a Raspberry Pi too (Models 3 or 4 recommended for this project) if you really want to code your project in Circuit Python.
As for Raspbian OS, there's already a multi-touch solution and the displays are available in the Adafruit Store.
https://www.youtube.com/watch?v=GKwRCDt2vWo Another excellent project by the Ruiz Brothers. https://www.adafruit.com/product/2718 It's not possible at this time to use this display with Circuit Python.
