I'm looking at this screen (https://www.adafruit.com/product/2354) and controller (https://www.adafruit.com/product/1590) combo, And everything I need for my project it has, apart from the fact that I can't tell if it supports multitouch. I can see in the library that you can read if the screen is touched at a point, which seems like it is built to support multitouch:
/* Touch screen */
void touchEnable(boolean on);
boolean touched(void);
boolean touchRead(uint16_t *x, uint16_t *y);
TL;DR: Basically I just need to know if this screen supports multitouch, and if so the board that is best used since the recommended touch driver is now discontinued (https://www.adafruit.com/product/1571).
Thank you!
