so I ordered 5 of these https://www.adafruit.com/product/5163 on June 9th for a project
Order #2863121-4474969773
They are Arduino controled with one of your 5V power supplies. 4 of them have been working fine, but one stopped working after a few days of usage.
I care less about the money and the replacement of the product and more about the fact that my confidence in this component is a bit shaky and I'm second guessing using them in a large project...
Any advice?
Ultrabright 4 watt NEOPIXEL stopped working
- jon_kessler
- dastels
Re: Ultrabright 4 watt NEOPIXEL stopped working
What's the amperage of the power supply? These should have at least a 2A supply.
Another possibility is overheating. From the product page:
DaveEach order comes with one RGBW NeoPixel LED on an aluminum PCB/holder/heatsink. Please note that even though the PCB acts as a heatsink, 4W is a lot of power to dissipate as heat so you may need an additional heatsink or fan or other cooling mechanisms!
- jon_kessler
This is the 10 Amp power supply that I was using. Product ID: 658
Do you suggest I customize with a heat sink?
- dastels
OK, that's more than enough current capacity.
The datasheet lists +85C as the max operating temperature. So if it's getting close to that you'll need to do something to cool it: generally a bigger heatsink and/or a fan.
