Can the RA8875 do vertical oriented displays, or only horizontal? Interested in using with PID 1596, the 5" 40 pin TFT with resistive touch - but it has to be capable of vertical display orientation.
Thanks,
Can the RA8875 do a VERTICAL orientation with the 1596?
- xanatos
- mikeysklar
Re: Can the RA8875 do a VERTICAL orientation with the 1596?
Dave,
It can be done based on the RA8875 user experience and from the datasheet.
What would you be driving the display with?
https://github.com/Bodmer/TFT_eSPI/issues/1485Rotation is a bit weird with this display. You have to modify both the write direction (to flip it to portrait) and the scan direction (to invert it horizontally and vertically) - I use them both in tandem. I missed it in the datasheet the first time around, because i wasn't thinking about altering the scan direction. It took me a bit to work it out, so I'm giving you head's up.
- xanatos
Mike,
Thanks for the response, this is good news and good reference material. Apologies for the delay in responding, been down for a few days with covid, lucky me lol
EDIT: I'll probably be using the SAMD51 based "CircuitBrains" available through Adafruit. Tiny footprint and just about every IO port is exposed, and I'm likely to use them all :)
