Hello.
I'm having problems with the LCD. I attached an image of how the LCD prints - it has the image skewed across the lcd and top row (left on the picture) and two rows from the left of LCD (bottom on the picture) are random pixel noize.
I also upload the code i used
I had to do some modifications to the code as it was not working with Arduino Win IDE 1.0 and presented a lot of errors with the library.
Board used was Mini Arduino Pro 386P @ 8MHz / 3.3V
Wiring was exactly as here: http://www.ladyada.net/products/18tftbreakout/
Plz help. I have been searching for eternity now for a solution
Adafruit 1.8 TFT display skewed
Re: Adafruit 1.8 TFT display skewed
does the example code work?
did you download the latest library?
- PlastiBots
FYI - I just got this LCD and ran across the same issue above... Found the below code in the sample. My LCD had the red tab (good think I did not take out the garbage!). So uncommented the redTab init and it worked.. with one exception - the image is upside down?!
// If your TFT's plastic wrap has a Green Tab, use the following
//tft.initR(INITR_GREENTAB); // initialize a ST7735R chip
// If your TFT's plastic wrap has a Red Tab, use the following
// since the display is shifted a little in memory
tft.initR(INITR_REDTAB); // initialize a ST7735R chip
