Hi all!
I'm looking for two rgb led source that I need for illuminate two different scenario:
1. first strip goes in the shower (first floor)
2. second strip goes in the living (ground floor)
I've choose to buy all here, but I have a simple question: what happen if I use 2 distinct RF Touch Wheel Controller (with one controller box each) that are at 10m distance and I am between controller boxes?
Is possible to setup the frequency?
Obviusly the RF Touch Wheel Controller is yours: https://www.adafruit.com/products/678
Thank you!
Multiple rgb strips with a RF Touch Wheel Controller each
- ale ale ale
Re: Multiple rgb strips with a RF Touch Wheel Controller each
if they're on different floors, they should still work OK
- ale ale ale
Thank you!
For real I want buy the Rgb one beacause there's not the cold white strip. Is possibile to remove or disable the remote controller after I set a favourite color?
Thank you very much!
if you dont touch it then it doesnt activate. you can also remove the battery
- ale ale ale
Eheheh buy the problem remains if the remote of the first floor command the controller box of the ground floor
the question is if it is possible to disable the remote on the controller box
Thank you for the quick answers!!!
sure, cover it in tinfoil!Ale Ale Ale wrote:Eheheh buy the problem remains if the remote of the first floor command the controller box of the ground floor
- ale ale ale
Ah ok! perfect!
Now I have another question: I need approximately 1.5m of strip for the shower and 7.0m for the living room. I think I'll buy 10m 60led/m rgb strip.
For connect to my house' electrical system I choose these components:
1. 12V 5A switching power supply (by cutting the cable to connect to the system, not to a generic power point) https://www.adafruit.com/products/352
2. Female DC Power Adapter for connect the power supply to the remote controller box https://www.adafruit.com/products/368
3. RF Touch Wheel Controller for Analog RGB LED Strips for control my strips https://www.adafruit.com/products/678
4. Waterproof Polarized 4-Wire Cable Set (only for the shower) https://www.adafruit.com/products/744
5. Heat Shrink Pack in order to restore the waterproof https://www.adafruit.com/products/344
6. RGB LED waterproof flexi-strip 60 LED https://www.adafruit.com/products/346
For the living I'll control the strip with a normal switch and, how I've told you above, I'll use the rf for choose the color the first time and (very very maybe) sometimes. If there are interference problems I'll use some tinfoil.
But the question now is: how I power my living strip that is more than 5 m long? What I have to do?
I'm sorry but I'm quite noob on these things, but I like that and I want to setup the system by myself
Thank you!
Thank you!
