Hardware SPI from the latest SSD1306 Oled Library?
satoer
Post by satoer »
I Want to use hardware SPI (from the Arduino UNO) to drive my SSD1306 based oled.
The provided library uses the much slower software (bitbanging) SPI:
https://github.com/adafruit/Adafruit_SSD1306
A year ago, NickGammon profided some adjustments to the code, to use the display with hardware SPI.
This post: http://forums.adafruit.com/viewtopic.ph ... 15#p103938
But if I look at the current code, it seems there’s been some heavy rewritten parts. And I can’t find the parts that needs to be replaced to use it with Hardware SPI.
Luckely, Github profides downloading older versions. And if I adjust the version from January:
https://github.com/adafruit/Adafruit_SS ... 561d7c472d
It works with Hardware SPI.
Now, my question. I’m not that skilled programmer (at least, not in C). Can someone point out what needs to be changed to use the current SSD1306 library with hardware SPI?
If I look at the library code, there seems to be references to hardware SPI commented out, for example:
void Adafruit_SSD1306::ssd1306_command(uint8_t c) {
  if (sid != -1)
    // SPI
    //digitalWrite(cs, HIGH);
    *csport |= cspinmask;
    //digitalWrite(dc, LOW);
    *dcport &= ~dcpinmask;
    //digitalWrite(cs, LOW);
    *csport &= ~cspinmask;
    fastSPIwrite(c);
  else
    // I2C
    uint8_t control = 0x00;   // Co = 0, D/C = 0
    Wire.beginTransmission(SSD1306_I2C_ADDRESS);
    Wire.write(control);
    Wire.write(c);
    Wire.endTransmission();
But uncommenting and commenting the “csport” code does not transform the library into hardware SPI.
adafruit_support_rick
Re: Hardware SPI from the latest SSD1306 Oled Library?
Post by adafruit_support_rick »
The current adafruit library supports hardware SPI. To use it, you only specify your RESET pin when you define your display object:
For example:
Adafruit_SSD1306 display(OLED_RESET);
satoer
Post by satoer »
Hi driverblock, thanks I didn’t know that.
I’ve made a test program that quickly draws a bitmap and clears the screen. spits the framerate on the serial port. With the old hardware SPI adjusted library I get a framerate of 34fps
With the new library I get a framerate of 16 fps if I define it with:
Adafruit_SSD1306 oled(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
If I define it with:
Adafruit_SSD1306 oled(OLED_RESET);
Nothing happens. It seems to hang on:
oled.begin(SSD1306_SWITCHCAPVCC);
Here’s the testcode I used:
#define OLED_DC 8
#define OLED_CS 10     // SPI slave-select
#define OLED_CLK 13    // hardware SPI clock
#define OLED_MOSI 11   // hardware SPI MOSI
#define OLED_RESET 7
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
//Adafruit_SSD1306 oled(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
const unsigned char __attribute__ ((progmem)) crownlinelogozw [] = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x80, 0x80, 0xC0, 0xE0, 0xE0, 0xE0, 0xF0, 0xF0, 0xF8, 0x78, 0x78, 0x78, 0x3C, 0x3C, 0x3C,
  0x3C, 0x3C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x18, 0x38, 0x38, 0x38, 0x70, 0x70, 0xE0,
  0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF8, 0xFC, 0xFE, 0xFE,
  0x7F, 0x1F, 0x0F, 0x0F, 0x07, 0x83, 0x81, 0x81, 0xC0, 0xC0, 0xC0, 0x60, 0x60, 0xE0, 0xE0, 0xE0,
  0xE0, 0xE0, 0xE0, 0xA0, 0xA0, 0x80, 0x80, 0x80, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0,
  0xC0, 0x81, 0x83, 0x87, 0x8E, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x79, 0x3C,
  0x3C, 0x3E, 0x9E, 0x9F, 0xDF, 0xCF, 0xCF, 0xEF, 0x6F, 0x67, 0x77, 0x37, 0x37, 0x3F, 0x1B, 0x1B,
  0x1B, 0x1B, 0x1B, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x07, 0x07, 0x07, 0x07, 0x07, 0x07, 0x87,
  0xC3, 0xC3, 0xE3, 0xF3, 0x7B, 0x3B, 0x1F, 0x1F, 0x0F, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x33, 0x71, 0xF9, 0xF8, 0xF8, 0xDC, 0x8C, 0x0E,
  0x06, 0x07, 0x03, 0x03, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x40, 0x60, 0x60, 0x30, 0x30, 0x18, 0x18, 0x1C, 0x8C, 0xCE, 0xC7, 0x67, 0x73,
  0x31, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x07, 0x0F, 0x0F,
  0x1E, 0x1E, 0x3C, 0x3C, 0x38, 0x38, 0x38, 0x78, 0x70, 0x70, 0x70, 0x70, 0x70, 0x30, 0x30, 0x30,
  0x38, 0x38, 0x18, 0x18, 0x1C, 0x0C, 0x0C, 0x0E, 0x06, 0x07, 0x03, 0x03, 0x01, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x00,
  0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
  0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0,
  0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0xC0, 0xC0,
  0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0,
  0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0xC0,
  0xC0, 0xC0, 0xC0, 0x00, 0x00, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0,
  0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0,
  0xFC, 0xFE, 0xFF, 0x83, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x07, 0x07, 0x00,
  0x00, 0xFF, 0xFF, 0x6E, 0x60, 0x60, 0xE1, 0xFF, 0xBF, 0x1F, 0x00, 0x20, 0xFC, 0xFE, 0xFF, 0x03,
  0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0xFF, 0xFE, 0xFF, 0x1F, 0xFF, 0xFC,
  0xE0, 0x00, 0xE0, 0xF8, 0x3F, 0x0F, 0x3F, 0xFF, 0xF8, 0xE0, 0x00, 0xE0, 0xFC, 0x3F, 0x07, 0x00,
  0xFF, 0xFF, 0x07, 0x0F, 0x1E, 0x3C, 0x78, 0xF0, 0xE0, 0xC0, 0x80, 0x00, 0xFF, 0xFF, 0xFF, 0x00,
  0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF,
  0xFF, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x07, 0x0F, 0x1E, 0x3C, 0x78, 0xF0, 0xE0, 0xC0, 0xC0,
  0x80, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x30, 0x30, 0x30, 0x30, 0x30, 0x71, 0x71,
  0x01, 0x03, 0x07, 0x0F, 0x0E, 0x1C, 0x1C, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x1E, 0x0F, 0x00,
  0x18, 0x1F, 0x1F, 0x1F, 0x18, 0x18, 0x00, 0x03, 0x07, 0x0F, 0x0E, 0x1C, 0x19, 0x1B, 0x1F, 0x0F,
  0x1E, 0x1C, 0x18, 0x18, 0x18, 0x18, 0x18, 0x1C, 0x0C, 0x0F, 0x07, 0x03, 0x01, 0x00, 0x00, 0x07,
  0x1F, 0x1F, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x07, 0x1F, 0x1F, 0x07, 0x01, 0x00, 0x18, 0x18,
  0x1F, 0x1F, 0x18, 0x18, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x07, 0x0F, 0x1F, 0x1F, 0x00,
  0x00, 0x18, 0x1F, 0x1F, 0x1F, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x1C, 0x00, 0x18, 0x1F, 0x1F,
  0x1F, 0x18, 0x18, 0x00, 0x18, 0x1F, 0x1F, 0x18, 0x18, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03,
  0x07, 0x0F, 0x1F, 0x1F, 0x00, 0x18, 0x1F, 0x1F, 0x1F, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x1E
int counter=0, SecondTimer=0;
void setup()
  Serial.begin(9600);
  Serial.println("Start setup" );
  SPI.begin ();
  Serial.println("SPI Started" );
  Serial.println("End setup" );
void loop()
  oled.drawBitmap(0, 0, crownlinelogozw ,128, 64, 1);
  oled.display();
  counter++;
  oled.clearDisplay();
  oled.display();
  counter++;
  if (millis() > (SecondTimer + 1000)) // 1 keer per seconde
    Serial.println(counter);
    SecondTimer=millis();
    counter=0;
What did I do wrong?
Which display are you using? There is a #define in the header file that needs to be changed if you are using the 128 X 32 display.
If you're using the 128x32 OLED, be sure to uncomment the "#define SSD1306_128_32" in the top of Adafruit_SSD1306.h to change the buffer size.
//   #define SSD1306_128_64
Check your wiring: It has to be like this:
Finally, connect the pins to your Arduino - GND goes to ground, Vin goes to 5V, DATA to digital 9, CLK to digital 10, D/C to digital 11, RST to digital 13 and finally CS to digital 12
Here the picture from the tutorial:
satoer
Post by satoer »
No, I’m using the 128x64 version.
So I’ts probably wrong “wired”.
My wiring is:
 #define OLED_DC 8
These are te preconfigured hardware SPI pins I should use. Besides the display, I also want to use a SD card on the same pins (except of course the CS).
From the SPI reference on the Arduino site: http://arduino.cc/en/Reference/SPI
On the Arduino Duemilanove and other ATmega168 / 328-based boards, the SPI bus uses pins 10 (SS), 11 (MOSI), 12 (MISO), and 13 (SCK). […]It is possible to use a pin other than pin 10 as the slave select (SS) pin. For example, the Arduino Ethernet shield uses pin 4 to control the SPI connection to the on-board SD card, and pin 10 to control the connection to the Ethernet controller.
(CS = SS)
So there’s a misconfiguration in the SSD1306 Library if you want to use hardware SPI?
Sorry, sorry - my mistake. I had a brain-cramp when I looked at the library code.
selects I2C, not hardware SPI. Looking again, the library does not do hardware SPI. Ignore everything I said.
Are you using a level-shifter with your 128X64?
satoer
Post by satoer »
Ah, so there’s no easy fix to adjust the new library code to hardware SPI like NickGammon has done in topic: http://forums.adafruit.com/viewtopic.ph ... 15#p103938 for the old library code?
Yes, I’m using a level shifter to transform the signal voltage to 3.3V ;)
Not that I know of. 'Fraid you're on your own.
NickGammon
Post by NickGammon »
I have amended the library to support hardware SPI. Documentation here:
http://arduino.cc/forum/index.php/topic,108542
Note that you will need to use different pins than in the tutorial. It's discussed in the above post.
The changes are pretty minimal. Maybe one day a define in "official" code will allow you to select them as an option.
satoer
Post by satoer »
Fantastic! Thank you NickGammon!
