Extended Raspberry Pi Library for the LPD8806
Re: Extended Raspberry Pi Library for the LPD8806
by karlm on Tue Oct 08, 2013 2:35 pm
Hey @packetslave, how exactly did you achieve the shared ground? To which ground point did you connect the external 5v power supply's ground to the RPi?
Karl
karlm
by timberjoe on Mon Nov 04, 2013 5:52 pm
I love this library, but I am having a slight coding problem. When I set a state for the strip with one script a led.fillOff() or led.all_off() everything works fine. If I want to leave the current state of the strip and just alter certain leds on a subsequent run (therefore not using led.fillOff() or led.all_off) to preserve the prior state all of the number addressing for the LEDs are messed up. Basically, it will always treat whatever led I try to set, or fill as 0 even if I specify otherwise. Any idea what I am doing wrong?
timberjoe
