Adalight with Prismatik (formerly Lightpack)
Re: Adalight with Prismatik (formerly Lightpack)
by michalcerny on Sun Dec 01, 2013 11:21 am
Hey, Thanks for prismatik but why is last versions not working with adalight? I used 5.9.6 but hotkeys disabled "A" on keyboard and versions 5.10.1 and 5.10.3 not support adalight, cant change device in device tab, thanks for answer :)
michalcerny
by hhagman on Sat Dec 28, 2013 7:02 am
michalcerny wrote:Hey, Thanks for prismatik but why is last versions not working with adalight? I used 5.9.6 but hotkeys disabled "A" on keyboard and versions 5.10.1 and 5.10.3 not support adalight, cant change device in device tab, thanks for answer :)
SOLVED
Had the same problem with the "A" key being disabled. It's something with the hotkeys that disables that specific key. The solution is to assign all the hotkeys with a command. The ones you don't use just assign them to something unuseful like cmd+F1, cmd+F2 etc...
This worked for me at least!
Cheers!
hhagman
by hhagman on Sun Dec 29, 2013 3:16 pm
Changed to version 10.5.4 because of increased stability and therefore looses possibility to toggle on/off lights with hotkey. Anyone know a workaround? Got the lightpack xbmc plugin installed but can't get it to turn on/off, any help?
Cheers!
hhagman
by Ronin on Tue Dec 31, 2013 4:58 am
Does anybody think it would be possible to run the Prismatik Socket API directly on a Arduino Uno with a Ethernet Shield?
Would be awesome, because then you could control your led's with your phone without having to run a pc...
Ronin
cron
