Issues getting Neopixel to work
Re: Issues getting Neopixel to work
by paulstoffregen on Tue Feb 26, 2013 8:32 pm
That high performance WS2811 library I mentioned is now available.
http://www.pjrc.com/teensy/td_libs_OctoWS2811.html
paulstoffregen
by hcgilje on Thu Feb 28, 2013 2:34 pm
thanks for the extremely detailed write-up, looking forward to testing the combination teensy 3 and the neopixel strip.
So far I have been happy with using the teensy 2 in combination with the lpd8806 strip, but this looks like the way to go for larger-scale projects.
hc
hcgilje
by tekn0slave on Thu Nov 27, 2014 5:11 am
I have a similar question about the holding of a single color. If you do a byte copy of the string and save that to memory somewhere, would it make swapping to that color faster than using the colorswipe? For instance if i wanted my strip to cycle on a button press to predefined colors (just for example since im more thinking of user defined images) could i create constants with the string data, then do a memcpy() to the string being sent on button press? Then to hold that color just need to loop refreshing the strip right?
tekn0slave
