Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
[Example]NeoPixel Strip Scrolling Cylon Eye! NOW WITH VIDEO!!!
Re: [Example]NeoPixel Strip Scrolling Cylon Eye! NOW WITH VIDEO!!!
by EternalCore on Thu Sep 19, 2013 3:30 am
mordecai131 wrote:Thank you for going through all that, unfortunately it's not working for me for some reason. I believe I used the code properly but I have a feeling it may be the type of board I'm using, chipKit uC32. After some experimenting I found that if I run 12 volts through the AC plug on the board and bypass the 5 volt regulator I can get the sticks to flash a pinkish color. But it does not respond to the code, even if I unplug the signal wire, reset the board, and even upload new code to the board which normally resets it as well the sticks continue to blink.
By running 12v through the NeoPixel bar you have killed it as its only rated for 7vDC MAX!... So this is why it's not working for you...
Power the whole thing with 5VDC (4-7V works) and you're ready to rock.
Source: http://www.adafruit.com/products/1426
Things I've Made Here:
1.[101-Help]~12v -> 5v 1.5A Regulated Power For NeoPixels.: http://goo.gl/uMXuk7
2.[Example]NeoPixel Strip Scrolling Cylon Eye!: http://goo.gl/4RzWQQ
EternalCore
by mordecai131 on Thu Sep 19, 2013 3:44 am
If I had killed the sticks wouldn't it have stopped lighting all together? They still light, but I hadn't tried the 12 volt trick till after I had tried your updated code. On the regulated 5 volts from the usb when I plug them in they flash for a very brief second and off again.
mordecai131
by EternalCore on Thu Sep 19, 2013 3:55 am
mordecai131 wrote:If I had killed the sticks wouldn't it have stopped lighting all together? They still light, but I hadn't tried the 12 volt trick till after I had tried your updated code. On the regulated 5 volts from the usb when I plug them in they flash for a very brief second and off again.
Not necessarily as they won't work right anymore is all in your case. And a single flash, with 5v, is normal for when you power up the bar without a signal going through it; before you applied the 12v through it.
In order for this script to work the NeoPixel Bar/Strip DIN wire has to be connected to the Digital Pin 6 on your board(Arduino).
EternalCore
by mordecai131 on Thu Sep 19, 2013 3:57 am
In which case before I applied the 12 volts it was wired that way. And it still does the flash without the signal wire even after the 12 volts, I may not have killed it but I'm not 100% sure.
mordecai131
by EternalCore on Thu Sep 19, 2013 4:09 am
mordecai131 wrote:In which case before I applied the 12 volts it was wired that way. And it still does the flash without the signal wire even after the 12 volts, I may not have killed it but I'm not 100% sure.
Run the strandtest and see if it works with your bar; if not then your bar is damaged. Do you have another bar to try that you didn't put 12v through it?
Also I hope your using DC Current to power your Arduino and not AC Current; Because These electronics are only designed to use DC Current, And using AC Current will damage them and or kill them..
EternalCore
by mordecai131 on Thu Sep 19, 2013 4:15 am
I just tried the stand test and it didn't work. But like I said it didn't work when I first got the sticks. I don't have another I can try unfortunately and I'm using a wall adapter like the one sold on adafruit except it has a switch on the face of the plug that switches from 3-12 volts and a range of settings in between. It's like something you'd charge your phone with but you can buy different tips for different devices.
mordecai131
by EternalCore on Thu Sep 19, 2013 4:21 am
mordecai131 wrote:I just tried the stand test and it didn't work. But like I said it didn't work when I first got the sticks. I don't have another I can try unfortunately and I'm using a wall adapter like the one sold on adafruit except it has a switch on the face of the plug that switches from 3-12 volts and a range of settings in between. It's like something you'd charge your phone with but you can buy different tips for different devices.
Start a new thread and post pics on how your Bar is wired up to your Arduino and what your Arduino is(etc), and that your bar isn't working. I and others will help you there; as this thread is for help with my script. As you have a hardware issue. :)
EternalCore
by mordecai131 on Thu Sep 19, 2013 4:27 am
Alright will do. Sorry, wasn't trying to takeover your thread or anything. :)
mordecai131
by EternalCore on Thu Sep 19, 2013 5:48 pm
mordecai131 wrote:Alright will do. Sorry, wasn't trying to takeover your thread or anything. :)
No Worries. Convo Continued here: Trouble Lighting a NeoPixel Stick
EternalCore
by EternalCore on Sat Oct 05, 2013 12:56 am
We need a place to post our stuff... Bill, rick or Adafruit can you guys make this possible and move this thread to it???
EternalCore
by char0k on Mon Dec 02, 2013 10:54 pm
really like what you've done and wondering if you would sell a completed setup?
could use it to liven up a black server room visible through a large window
char0k
by XW4 on Mon Jul 27, 2015 4:04 pm
Thanks You EternalCore for this ONE WAY code.
I know Arduino could drive many differents stripes using differents pin out.
Did you know how i can drive 3 differents stripes with differents colors and different wait_t for each stripes/pin out?
I follow this learn article there too if that's could help
https://learn.adafruit.com/multi-tasking-the-arduino-part-3/overview
The final goal is to drive 3 different segments of neopixel with One Way EternalCore code on 3 different pin out on Arduino.
EternalCore wrote:
gozeeta wrote:Awesome! Thanks! Playing around, I'm trying to make the eye go only one way, have a shorter overall width (3 LED instead of 5), and waiting a couple seconds between each "pulse." Here's what I have so far:
-snip-
But now that I've removed the scroll down, the last two pixels at the end never turn off! I wonder what I did wrong...
Here you go I added a new script just for you, for what you are trying to do: https://github.com/EternalCore/NeoPixel ... OneWay.ino :)
To change the timing of between pulses change the number in int 'refresh', to change the speed of it scrolling change the number in int 'wait_T' and 1000 is equal to 1second.
-Enjoy
XW4
