Neo pixel fade in/out?
AlwaysHuman
Post by AlwaysHuman »
Hey!
Does anyone know of a way to make neo pixel strips fade on and off? I'm trying to make something where when you tap a button, all the lights in the strip pop on, then fade off.
EternalCore
Re: Neo pixel fade in/out?
Post by EternalCore »
Gimmy a few and I'll write you a quick example sketch. ;)
EternalCore
Note: A more advanced example is 2 posts below this one. ;)
Here you go:
#define PIN 6
#define PIXEL 60
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  int R = 0;
  int G = 0;
  int B = 0;
  //Fade in
  for(R && G && B; R<126 && G<126 && B<126; R++ && G++ && B++) {
    for(int i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, strip.Color(R, G, B));
      strip.show();
      delay(0);
    delay(1);
  //Fade Out
  for(R && G && B; R>-1 && G>-1 && B>-1; R-- && G-- && B--) {
    for(int j=0; j<strip.numPixels(); j++) {
      strip.setPixelColor(j, strip.Color(R, G, B));
      strip.show();
      delay(0);
    delay(1);
-Enjoy.
AlwaysHuman
Thank you so much!!!!! :D
EternalCore
AlwaysHuman wrote:Thank you so much!!!!! :D
You're welcome. Here's a more advanced example that you can set the amount it updates by to speed it up:
#define PIN 6
#define PIXEL 60
  strip.begin();
  int R = 0;
  int G = 0;
  int B = 0;
  int finCount=5;
  int foutCount=5;
  int Rset = 125;
  int Gset = 125;
  int Bset = 125;
  int waitT = 5;
  //Fade in
  while(1){ //using an inf loop to be more custom.
  //Protect the strand from higher then 255 values
  if(R>255 || G>255 || B>255) { break; } //DO NOT DELETE OR ALTER THIS LINE.
    //break the inf loop if the color is higher then what its set at.
    if (R>Rset+1 && G>Gset+1 && B>Bset+1)  {
      //ReSet the RGB to set values.
      R=Rset;
      G=Gset;
      B=Bset;
      break;
    //update the strip
      strip.show();
      delay(0);
    //increase by the set amount
    R=R+finCount;
    G=G+finCount;
    B=B+finCount;
    delay(waitT);
  //Fade Out
  //break the inf loop if the color is off
    if (R<0 && G<0 && B<0)  {
      //ReSet the RGB to 0 values.
      R=0;
      G=0;
      B=0;
      break;
    //update the strip
      strip.show();
      delay(0);
    //Decrease by the set amount
    R=R-foutCount;
    G=G-foutCount;
    B=B-foutCount;
    delay(waitT);
-Enjoy
Gixxerfool
Post by Gixxerfool »
#define PIN 6
#define PIXEL 60
  strip.begin();
  int R = 0;
  int G = 0;
  int B = 0;
  int finCount=5;
  int foutCount=5;
  int Rset = 125;
  int Gset = 125;
  int Bset = 125;
  int waitT = 5;
  //Fade in
      R=Rset;
      G=Gset;
      B=Bset;
      break;
    //update the strip
      strip.show();
      delay(0);
    R=R+finCount;
    G=G+finCount;
    B=B+finCount;
    delay(waitT);
  //Fade Out
      R=0;
      G=0;
      B=0;
      break;
    //update the strip
      strip.show();
      delay(0);
    R=R-foutCount;
    G=G-foutCount;
    B=B-foutCount;
    delay(waitT);
-Enjoy
I realize this post is quite old, but I had a question on this sketch.
I am looking to have a neopixel jewel fade in once on reset. Can I copy the fade in from the first example, adjust the declarations and put it in my void setup?
Thanks in advance.
PS
I actually found your Cylon eye for the same project.
