CONTROLLING MULTIPLE NEOPIXEL STRIPS WITH MULTIPLE PINS ON A
by DanMan1185 on Sun Aug 10, 2014 5:25 am
Hello Everybody,
I am working on a lighting project for my wedding. My vision is to have 12 of the 60 LED per meter NeoPixel strips hanging from the ceiling. These strips would hang in a 4 by 3 grid with 2 meter spacing. A have made a rough sketch of my vision here. This project is very similar to the Immersion art project posted by Adafruit customer ramien
Before I set out to do this, I have a few questions:
  1. Is there a library that allows the Mega 2560 to communicate to multiple strips using multiple output pins? I ask this because it will be a real pain to run the output of one strand back up the strip, across the ceiling, and to the input of the next strip. I am worried about clutter as well as the signal losing strength. Do you have any ideas?
  2. Do you suspect I will have issues with loss of strength of my digital signal? If the Mega is in the middle of the 3 X 4 m grid (and I can communicate on multiple output pins), the digital communication line may need to about 3 meters in its longest run before reaching the input of the furthest strand. If I cannot communicate on multiple output pins, then I will have to run the output of one strand up to the input of the next. That's a 1 meter up the strand, then 2 meters to the next strand 12 times over, so about 36 meters of non-strip wire! Any ideas on how can I mitigate signal strength problems?
Thanks so much!
Danny
DanMan1185
Re: CONTROLLING MULTIPLE NEOPIXEL STRIPS WITH MULTIPLE MEGA
by adafruit_support_bill on Sun Aug 10, 2014 7:08 am
1 - yes, you simply declare multiple strips and assign each one a different pin.
2 - 1 meter seems to be the practical distance limit for Arduino to neopixel or for spacing between pixels. Beyond that, you need some sort of buffering. One trick is to use a 'blind' pixel as a repeater. Others have had luck using RS485 line drivers over longer distances.
viewtopic.php?f=47&t=49543&p=249621
by michaelmeissner on Sun Aug 10, 2014 8:09 am
In terms of the signal length, etc. it might be easier to have cheaper microprocessors handle each strand, and have them communicate with a master processor for assignments. If you use i2c, you might be able to do it with your brain processor in the middle, and separate cat-5 cables to carry power/i2c to each processor (max i2c distance is about 6 meters). Something like a 5v trinket would work.
Otherwise you might need a radio solution like nRF24L01+, which adds to the cost (radios, plus beefier slave processors to handle nRF24L01+).
michaelmeissner
Re: CONTROLLING MULTIPLE NEOPIXEL STRIPS WITH MULTIPLE PINS
by DanMan1185 on Sun Aug 10, 2014 8:31 am
First off, there was a terrible typo in my original posting title. It says "Controlling Multiple Neopixel Strips with Multiple Mega 2560s." It should have said "Controlling Multiple Neopixel Strips with a Single Mega 2560."
adafruit_support_bill, now that the title of my post is adjusted, can you confirm that I can run multiple pins as outputs simultaneously to control multiple strips? My goal here is to make the structure more like a "spiderweb" rather than a long continuous line of LEDs. I imagine some pseudocode would be would look something like:
loop
send LED status command 1 to 60 LEDs on strip A using pin 4 //this would function identically to the Adafruit_Neopixel.h library
send LED status command 2 to 60 LEDs on strip B using pin 5
send LED status command 3 to 60 LEDs on strip C using pin 6
and so on
I definitely thought about pairing each strip with its own microcontroller and then having a master "conductor" microcontroller send i2c commands to each of the cheaper microcontrollers. That might be the best way to go, but whenever I want to update my library of blink patterns, I would have to reprogram all the cheaper microcontrollers.
DanMan1185
by adafruit_support_bill on Sun Aug 10, 2014 9:30 am
Yes. You can control multiple strips from multiple pins on the same processor. Just declare them with different pins and give them different names:
Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(60, PIN4, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip2 = Adafruit_NeoPixel(60, PIN5, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip3 = Adafruit_NeoPixel(60, PIN6, NEO_GRB + NEO_KHZ800);
by DanMan1185 on Sun Aug 10, 2014 9:40 am
Wow, great! I will give it a go once my strips come in :)
DanMan1185
by DanMan1185 on Wed Aug 13, 2014 11:02 am
FYI: this article on FastLED's GitHub page solved my problems!
DanMan1185
