Neopixel Painter Library issue
by Brickboy30 on Sat Aug 16, 2014 9:03 pm
I am trying to get the Neopixel Painter to work but the code gives me a whole bunch of error messages. I have had other people look at it, installed the libraries and downloaded the code multiple time but to still no avail. The SDFat library seems to be the problem. I am sort of a beginner at Arduino, so dummying it down would be much appreciated.
Arduino Error.jpg (188.98 KiB) Viewed 10 times
Brickboy30
Re: Neopixel Painter Library issue
by pburgess on Sun Aug 17, 2014 1:59 am
I'd try reinstalling the Arduino IDE. The fact that it's having trouble with common types like 'uint8_t' suggests something may've gone corrupt. I was able to compile the project using the same code and setup (Arduino 1.0.5 on Windows, Uno board selected).
pburgess
by Brickboy30 on Sun Aug 17, 2014 8:18 am
Thank you for the help. I will try that and hope it works.
Brickboy30
by Brickboy30 on Sun Aug 17, 2014 4:10 pm
I have reinstalled the IDE and still get an error message... The message is shorter, though. Have re-installed this library multiple times to no avail.
Arduino: 1.5.7 (Windows Vista), Board: "Arduino Uno"
Build options changed, rebuilding all
In file included from NeoPixel_Painter.ino:35:0:
C:\Users\Kris\Documents\Arduino\libraries\SDFAT/SdFat.h:38:20: fatal error: SdFile.h: No such file or directory
 #include <SdFile.h>
compilation terminated.
  enabled in File > Preferences.
Brickboy30
by pburgess on Mon Aug 18, 2014 1:40 am
Try adding this to the sketch before any of the other includes:
#include <SdFile.h>
Any change? Same error message, about not finding the file?
Which version of SdFat -specifically- are you using? I've noticed it's bounced around to three different locations.
pburgess
by Brickboy30 on Mon Aug 18, 2014 2:12 pm
It compiled with me adding the included Arduino SD and SPI libraries. I have not gotten it to work on the arduino, but I think my soldering job is at fault.
Brickboy30
by lohrphoto on Thu Sep 05, 2019 1:32 am
Hello!
I am having a similar problem with the neopixel painter sketch, only the message I am getting is Error ./gamma.h no such file or directory. I see the library in the neopixel painter folder, but it does not recognize it as a library for some reason. Do I need to move the gamma.h file somewhere different for it to be recognized?
lohrphoto
