Hello!
I have an interesting predicament. I am using a Trinket with a NeoPixel stick and no matter what I do, the strip will light up completely white and not respond to any code on the trinket. I have tried all of the example sketches I could find, and changed the pin number and strip length to fit. I know the trinket is working because I can change the on board LED. I am powering it from a PowerBoost 500+ running off a 2000 mAh Li-Po battery (I connected the power output of the PowerBoost to the batt connections on the back of the trinket). Here are my connections on the Trinket:
Trinket NeoPixel Stick
Bat+-----------5v
Gnd------------Gnd
#0-------------Din
NeoPixel Stick Stuck on White
Re: NeoPixel Stick Stuck on White
Post photos showing all your soldering and connections. Also post the code you are using and we'll take a look.
- wbix
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN 0
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 8
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN);
int delayval = 1000; // delay for half a second
pixels.begin(); // This initializes the NeoPixel library.
pinMode(1, OUTPUT);
digitalWrite(1, HIGH);
// For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
for(int i=0;i<NUMPIXELS;i++){
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
pixels.setPixelColor(i, pixels.Color(0,150,0)); // Moderately bright green color.
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval); // Delay for a period of time (in milliseconds).
- davidl13
From what I've seen, "whiteouts" are generally the result of a strip's (or ring's) Din peak voltage being too close to the strip's (or ring's) primary power voltage. You can't see the issue with a normal DMM - it requires a scope.
First, always make sure there's a common ground between the strip/ring and the driving device. Try powering the driving device at a slightly reduced voltage relative to the strip/ring. At 5V I usually power the driving device through a couple of 1N4001's. (And always follow the recommendations in the NeoPixel UberGuide.)
I've also noticed that if I power the strip/ring at 3.6V or so (which still gets plenty bright) I no longer need the diodes for the driving device's power.
Note that when you're experimenting with this kind of stuff a full power cycle of the strip/ring and the driving device may be required: I've seen strips/rings appear to get stuck in a whiteout state and ignore the reduced-voltage bitstream. When the strip/ring itself was power cycled it all suddenly "just worked".
I hope this helps. "works for me..."
- jamesmcintoshjr
having the same problem with a neopixel ring stuck on white, not responding to code, etc. I'm using basically the kit from the photo ring light project (except my 3.7v li-poly was sent out in a different shipment so I have yet to use that battery). I'm running off usb power and have the same thing. 24 pixel ring with a 5v trinket, won't respond to code leveling out the brightness or changing the colour, I guess I'll have to see how it reacts when I get the proper battery.
- davidl13
Just as a test can you code in a cap to the brightness levels (say, maybe 17) and power everything from 3 1.5V D cells with a 1N4001 to drop the voltage to 3.9 V. Just sayin'...
"Gollum hates the stinky USB power!" ;-)
- wbix
I could only find 2 of those diodes lying around. Do you think that will be enough? Also, I am curious to know how that drops the voltage (being somewhat of a beginner).
Just to confirm, I should connect the diodes in series on the power running to the control device, right?
When using a single supply like that, we generally we recommend running power and ground directly to the pixels and then run wires from there back to the microcontroller. That will ensure that the Neopixel power voltage is at least as high as the signal voltage.
With the power daisy-chained from the processor to the Neopixels as you have it, there will be a voltage drop on the power wires from the microcontroller to the pixels proportional to the current being drawn. Since there is negligible current on the signal wire, the voltage drop on that will be negligible as well.
- davidl13
In this case you can think of a diode as a "one-way resistor". It allows current flow in only one direction with some voltage drop (~0.6 V here). Two in series is perfect for this experiment, just be aware of the diodes' orientation/polarity. If they aren't right you'll get no voltage.
- ElectronicOz
Don't want to but in, but Do you have the resistor on the data line?
Also the setup string doesn't look right.
The line I use is like this:
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LED_Loop, PIN, NEO_GRB + NEO_KHZ800);
And be sure that last part is right. I had/used the "OLD" KHZ400 and the ring went nuts.
If not specified, the third parameter of the constructor defaults to NEO_GRB + NEO_KHZ800.
https://github.com/adafruit/Adafruit_Ne ... NeoPixel.h
Adafruit_NeoPixel(uint16_t n, uint8_t p=6, uint8_t t=NEO_GRB + NEO_KHZ800);
- davidl13
Not at all, that's an important point that definitely should be checked. I was trying to describe to them what I'd been seeing recently and was assuming (!) they each had the resistor in place.Don't want to but in...
I do wish they'd report back with success or not...if only for the benefit of future readers.
- jamesmcintoshjr
so, received the 3.7v lipo battery, so now I have all the parts from the camera ring light kit, everything is wired up correctly, I've gotten the trinket to respond to the blink sketch, and I've loaded the code from the learnign project tutorial. I get my neopixel to light up no problem same as before. I've even changed the pin out to 1, and changed the data input wire to 1 on the trinket and it works fine, so the trinket is seeing some of the code. I modified the code to this to get a different colour out of the neopixel-
and still nothing, can't unstick the neopixel from white. Tried a few other things like lighting up select pixels, nothing. Do I have a bad neopixel ring?
#define N_PIXELS 24 // Number of pixels you are using
#define LED_PIN 1 // NeoPixel LED strand is connected to GPIO #0 / D0
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_PIXELS, LED_PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
// you can change the brightness to lower if its too bright!
strip.setBrightness(255); // Set LED brightness 0-255
colorWipe(strip.Color(0, 125, 180),0); // fill the strip with all white
strip.show(); // Update strip
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
Last edited by adafruit_support_bill on Sat Sep 27, 2014 5:42 am, edited 1 time in total.
Reason: please use the </> button when submitting code. press </>, then paste your code between the [code] [/code] tags.
- ElectronicOz
I'm not a rocket scientist, but here's what I see:
That is wrong.
Why have an open { and the close } straight after each other?
Where is C defined/declared/what ever?
Try this one:
(MODIFY the required pins)
strip.show();
That is wrong.
Try this one:
Test of NeoPixel Ring
This code should show one White LED stepping around the ring
#define LED_Loop 16
#define PIN 6 // This is defining which Arduino pin is driving the Pixel ring
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
void setup()
// put your setup code here, to run once:
Serial.begin(9600);
strip.begin();
strip.setBrightness(128);
// strip.show(); // Initialize all pixels to 'off'
delay(2000);
void loop()
for (byte i=0;i<LED_Loop;i++)
Serial.println(i);
strip.setPixelColor(i, 0x0AAAA0);
strip.setPixelColor(i-1, 0x000000);
if (i == 0)
strip.setPixelColor(Loop, 0x000000);
strip.show();
delay(1850);
Last edited by adafruit_support_bill on Sat Sep 27, 2014 5:44 am, edited 1 time in total.
- davidl13
@jamesmcintoshjr: did you try what I suggested above and if so, what were the results?
