Driving 2X RA8875 off of one microcontroller, can it be done
- local_dani_21
Re: Driving 2X RA8875 off of one microcontroller, can it be
I would be SOO thankful! Of course in the meantime I'll rewire the thing. But since so far I've ever only heard that it «should theoretically be possible», there is a chance that it actually doesn't work with two on the same bus (which would be too bad since I bought so many displays to work together).
Thanks for getting another one! Best regards, Dani
- local_dani_21
Hi Rick
Were you able to get another RA8875 with display? Are you able to drive two at the same time? Thank's for helping! Dani
- adafruit_support_rick
Got it this morning. I might not have time to check it out until tomorrow. Pretty tied up today.
- local_dani_21
Great! I have an almost free weekend for thinkering!
OK, I tried it out. It came right up and worked for me. I wired it all up and verified that the first RA8875 worked all by itself, then I verified that the second RA8875 worked all by itself, then I verified that they both worked together.
BTW - here's the code I hacked up for testing:
This is an example for the Adafruit RA8875 Driver board for TFT displays
---------------> http://www.adafruit.com/products/1590
The RA8875 is a TFT driver for up to 800x480 dotclock'd displays
It is tested to work with displays in the Adafruit shop. Other displays
may need timing adjustments and are not guanteed to work.
Adafruit invests time and resources providing this open
source code, please support Adafruit and open-source hardware
by purchasing products from Adafruit!
BSD license, check license.txt for more information.
All text above must be included in any redistribution.
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
// Library only supports hardware SPI at this time
// Connect SCLK to UNO Digital #13 (Hardware SPI clock)
// Connect MISO to UNO Digital #12 (Hardware SPI MISO)
// Connect MOSI to UNO Digital #11 (Hardware SPI MOSI)
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
#define RA8875_INT_2 2
#define RA8875_CS_2 8
#define RA8875_RESET_2 7
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
Adafruit_RA8875 tft2 = Adafruit_RA8875(RA8875_CS_2, RA8875_RESET_2);
uint16_t tx, ty;
void tftSetup(Adafruit_RA8875 *tft)
tft->displayOn(true);
tft->GPIOX(true); // Enable TFT - display enable tied to GPIOX
tft->PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft->PWM1out(255);
// With hardware accelleration this is instant
tft->fillScreen(RA8875_WHITE);
// Play with PWM
for (uint8_t i=255; i!=0; i-=5 )
tft->PWM1out(i);
delay(10);
for (uint8_t i=0; i!=255; i+=5 )
tft->PWM1out(i);
delay(10);
tft->PWM1out(255);
tft->fillScreen(RA8875_RED);
delay(500);
tft->fillScreen(RA8875_YELLOW);
delay(500);
tft->fillScreen(RA8875_GREEN);
delay(500);
tft->fillScreen(RA8875_CYAN);
delay(500);
tft->fillScreen(RA8875_MAGENTA);
delay(500);
tft->fillScreen(RA8875_BLACK);
// Try some GFX acceleration!
tft->drawCircle(100, 100, 50, RA8875_BLACK);
tft->fillCircle(100, 100, 49, RA8875_GREEN);
tft->fillRect(11, 11, 398, 198, RA8875_BLUE);
tft->drawRect(10, 10, 400, 200, RA8875_GREEN);
tft->fillRoundRect(200, 10, 200, 100, 10, RA8875_RED);
tft->drawPixel(10,10,RA8875_BLACK);
tft->drawPixel(11,11,RA8875_BLACK);
tft->drawLine(10, 10, 200, 100, RA8875_RED);
tft->drawTriangle(200, 15, 250, 100, 150, 125, RA8875_BLACK);
tft->fillTriangle(200, 16, 249, 99, 151, 124, RA8875_YELLOW);
tft->drawEllipse(300, 100, 100, 40, RA8875_BLACK);
tft->fillEllipse(300, 100, 98, 38, RA8875_GREEN);
// Argument 5 (curvePart) is a 2-bit value to control each corner (select 0, 1, 2, or 3)
tft->drawCurve(50, 100, 80, 40, 2, RA8875_BLACK);
tft->fillCurve(50, 100, 78, 38, 2, RA8875_WHITE);
void setup()
Serial.begin(9600);
Serial.println("RA8875 start");
/* Initialise the display using 'RA8875_480x272' or 'RA8875_800x480' */
if (!tft.begin(RA8875_800x480)) {
Serial.println("RA8875 Not Found!");
while (1);
Serial.println("Found RA8875");
Serial.println("RA8875 2 start");
if (!tft2.begin(RA8875_800x480)) {
Serial.println("RA8875 2 Not Found!");
while (1);
Serial.println("Found RA8875 2");
tftSetup(&tft);
tftSetup(&tft2);
pinMode(RA8875_INT, INPUT);
digitalWrite(RA8875_INT, HIGH);
tft.touchEnable(true);
Serial.print("Status: "); Serial.println(tft.readStatus(), HEX);
Serial.println("Waiting for touch events ...");
void loop()
float xScale = 1024.0F/tft.width();
float yScale = 1024.0F/tft.height();
/* Wait around for touch events */
if (! digitalRead(RA8875_INT))
if (tft.touched())
Serial.print("Touch: ");
tft.touchRead(&tx, &ty);
Serial.print(tx); Serial.print(", "); Serial.println(ty);
/* Draw a circle */
tft.fillCircle((uint16_t)(tx/xScale), (uint16_t)(ty/yScale), 4, RA8875_WHITE);
- local_dani_21
Thank you so much!
I feel of course completely stupid and am very relieved to know that it can be done. I'll try it tonight. Again.
Best regards, Dani
Best regards, Dani
- local_dani_21
So far I only get the same results as ever. I try to write down what I do - hopefully you'll find a detail I have overseen.
Wiring:
Uploading your code, I get
However, if I take RA8875-2 out of the breadboard (leaving all the cables in it's places) and comment out all references to RA88752, the frist display works flawlessly.
On the other side, if I put RA88752 back onto the breadboard an remove the first RA8875 and comment out all references to RA88751 (again leaving all cables in place), the second displays works well.
They do not work well as long as the three SPI-wires connect both the RA8875s - it seems.
Is there a speciality in your wiring? Do you wire something differently compared to me? Thanks for helping, Dani
Wiring:
Arduino Yun | RA88751 | RA88752
5V | VIN | VIN
GND | GND | GND
10 | CS |
9 | RST |
3 | INT |
8 | | CS
7 | | RST
2 | | INT
SCK | SCK | SCK
MOSI | MOSI | MOSI
MISO | MISO | MISO
RA8875 start
RA8875 Not Found!
The only difference is that I'm using a Uno and you're using a Yun. That shouldn't make a difference, but do you have a Uno to try it with?
- local_dani_21
I can't believe it: Using an UNO, the setup with two RA8875's works perfectly, using a YUN, it doesn't work. Does anyone have an explanation for this? What is different with the two processors? I assume something with the SPI-port, but I of course don't know? Timing?
- local_dani_21
PS: I've tried the two-display setup over SPI with Arduino Yun (Atmel 32u4), Teensy++ 2.0 (Atmel AT90USB1286), Teensy 3.1 (MK20DX256), they all work when only 1 RA8875 is connected.
Only when I use a Atmel 328P (Arduino UNO), I can use 2 RA8875's at the same time. You might want to add this information to your product-website https://www.adafruit.com/product/1590.
Is there any chance that you would consider digging into the timing of the SPI library to find out where the bug lies?
Should I post this as a problem at the http://www.arduino.cc-website?
Are you using Arduino 1.5.8? We've seen some strange timing problems with that, and I believe they have rewritten the SPI library for that release. Have you got an earlier version you can try this with?
If you think it's a bug in the SPI library, then the Arduino forums would be the place to post about this problem.
- local_dani_21
I tried it with Arduino IDE 1.5.7 as well as with Arduino IDE 1.5.7 -> no difference.
- tdicola
Are you still powering everything off a USB connection to a laptop/computer? If so try switching to an external power supply--I have a feeling it might be a power issue with both displays and the Yun taking a little more power than the USB port can provide. Remember the Yun has a full Linux processor with WiFi and an ATmega processor so it can pull much more current than a normal Arduino Uno with just the ATmega (in my testing the Yun pulled about about 250-300 mA of current alone).
As far as powering the Yun goes, it's a little trickier since it doesn't have any onboard voltage regulator. You'll want to use a 5V USB power source, like you might use to charge a phone, and plug a micro USB cable into the Yun's programming port and the power supply.
Give using an external power supply a try and let's see if it runs both displays.
