Re: Driving 2X RA8875 off of one microcontroller, can it be
paulstoffregen wrote:Rick, that's the nRF8001 schematic.
I'm working on a RA8875 conflict today. I fixed nRF8001 a couple days ago!
local_dani_21 wrote:PPS: Adafruit: Is there a possibility that you could coordinate with Paul if maybe his changes to the RA8875 library could become part of your library so that it would work out of the box with a greater variety of microcontrollers?
This is an example for the Adafruit RA8875 Driver board for TFT displays
---------------> http://www.adafruit.com/products/1590
The RA8875 is a TFT driver for up to 800x480 dotclock'd displays
It is tested to work with displays in the Adafruit shop. Other displays
may need timing adjustments and are not guanteed to work.
Adafruit invests time and resources providing this open
source code, please support Adafruit and open-source hardware
by purchasing products from Adafruit!
BSD license, check license.txt for more information.
All text above must be included in any redistribution.
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
// Library only supports hardware SPI at this time
// Connect SCLK to T31 Digital #13 (Hardware SPI clock)
// Connect MISO to T31 Digital #12 (Hardware SPI MISO)
// Connect MOSI to T31 Digital #11 (Hardware SPI MOSI)
#define RA8875_CS 10
#define RA8875_RESET 9
#define RA8875_CS_2 8
#define RA8875_RESET_2 7
#define RA8875_CS_3 6
#define RA8875_RESET_3 5
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
Adafruit_RA8875 tft2 = Adafruit_RA8875(RA8875_CS_2, RA8875_RESET_2);
Adafruit_RA8875 tft3 = Adafruit_RA8875(RA8875_CS_3, RA8875_RESET_3);
uint16_t tx, ty;
void setup()
Serial.begin(57600);
while(!Serial){}
Serial.println("RA8875 start");
/* Initialise the display using 'RA8875_480x272' or 'RA8875_800x480' */
if (!tft.begin(RA8875_800x480)) {
Serial.println("RA8875 Not Found!");
while (1);
Serial.println("Found RA8875");
Serial.println("RA8875 2 start");
if (!tft2.begin(RA8875_800x480)) {
Serial.println("RA8875 2 Not Found!");
while (1);
Serial.println("Found RA8875 2");
Serial.println("RA8875 3 start");
if (!tft3.begin(RA8875_800x480)) {
Serial.println("RA8875 3 Not Found!");
while (1);
Serial.println("Found RA8875 3");
tftSetup(&tft);
tftSetup(&tft2);
tftSetup(&tft3);
void loop()
void tftSetup(Adafruit_RA8875 *tft)
tft->displayOn(true);
tft->GPIOX(true); // Enable TFT - display enable tied to GPIOX
tft->PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft->PWM1out(255);
// With hardware accelleration this is instant
tft->fillScreen(RA8875_WHITE);
// Play with PWM
for (uint8_t i=255; i!=0; i-=5 )
tft->PWM1out(i);
delay(10);
for (uint8_t i=0; i!=255; i+=5 )
tft->PWM1out(i);
delay(10);
tft->PWM1out(255);
tft->fillScreen(RA8875_RED);
delay(500);
tft->fillScreen(RA8875_YELLOW);
delay(500);
tft->fillScreen(RA8875_GREEN);
delay(500);
tft->fillScreen(RA8875_CYAN);
delay(500);
tft->fillScreen(RA8875_MAGENTA);
delay(500);
tft->fillScreen(RA8875_BLACK);
// Try some GFX acceleration!
tft->drawCircle(100, 100, 50, RA8875_BLACK);
tft->fillCircle(100, 100, 49, RA8875_GREEN);
tft->fillRect(11, 11, 398, 198, RA8875_BLUE);
tft->drawRect(10, 10, 400, 200, RA8875_GREEN);
tft->fillRoundRect(200, 10, 200, 100, 10, RA8875_RED);
tft->drawPixel(10,10,RA8875_BLACK);
tft->drawPixel(11,11,RA8875_BLACK);
tft->drawLine(10, 10, 200, 100, RA8875_RED);
tft->drawTriangle(200, 15, 250, 100, 150, 125, RA8875_BLACK);
tft->fillTriangle(200, 16, 249, 99, 151, 124, RA8875_YELLOW);
tft->drawEllipse(300, 100, 100, 40, RA8875_BLACK);
tft->fillEllipse(300, 100, 98, 38, RA8875_GREEN);
// Argument 5 (curvePart) is a 2-bit value to control each corner (select 0, 1, 2, or 3)
tft->drawCurve(50, 100, 80, 40, 2, RA8875_BLACK);
tft->fillCurve(50, 100, 78, 38, 2, RA8875_WHITE);
brian49 wrote:had the issue been reported to RAIO Technologies?
