Hi. I have set up my raspbian using the script from adafrui.it/pitftsh. I have a picture on the screen but cannot use the touch functionality. Any ideas what the problem could be?
If I schould provide any logs pls let me know which one.
pitft touch screen not working
- Franklin97355
Re: pitft touch screen not working
There are two PiTFT screens capacitive and resistive did you download the correct version? Which PiTFT do you have?
Sorry I don't know which version I have. In the order it says "PiTFT Mini Kit - 320x240 2.8" TFT+Touchscreen for Raspberry Pi[ID:1601]"
- Franklin97355
1601 is the resistive screen and the instructions are here https://learn.adafruit.com/adafruit-pit ... sy-install
yes I have done the "DIY Installer script"-part. But no working touchscreen
- Franklin97355
If you have an extra SD card or haven't add anything to the one you have you might consider downloading the pre compiled image with the drivers already installed as a test.
I have just done that, with the same result.
I assembled the TFT on my own. May it be possible that I can see an image on the screen but no touch screen support, due bad soldering joints?
- Franklin97355
Could you post clear pictures of both sides of your board showing any soldering you have done and the connections to it?
We'll take a look.
We'll take a look.
Her is a picture of the soldering points for the GPIO Connector.
- 20141012_114336.jpg (75.59 KiB) Viewed 2104 times
Any Ideas?
I tried another Raspberry, same issue!
- Franklin97355
Nope. Please email [email protected] with a link to this thread for a replacementAny Ideas?
- fredi57
hi..my name is manfred scheer from vienna, austria, europe...
i have the same probz wis pitft+ from adafruit industry.
i got 2 ident displays from semaf electronics in vienna, austria..1 display was not working properly, so i go back to semaf electronics and let try mr. semaf another new display wis original image for raspberry ...the other display is working properly..
so, i know that the 1. display is defect..i thought at first my software is the reason..what can i do now ?
thankyou for ur help.
with friendly regards
manfred scheer
manfred scheer
