NeoPixel Power Question - Costume Project
by kagatoamv on Thu Oct 30, 2014 11:24 pm
I've got a costume project I've put together using 110 NeoPixels on five separate data lines, controlled by an Arduino Uno and powered by one of the USB Battery Pack for Raspberry Pi - 10000mAh - 2 x 5V.
110 NeoPixles is to much of a power draw to run off the 5v from the arduino board, so I am considering using one of the USB ports on the battery pack to run power to the board, then the other to run power to the NeoPixles, by connecting it to a usb breakout for the +5v, but I'm not sure how to wire that up, because I know they're supposed to have a common ground.
Anyone have any suggestions?
-Nic
kagatoamv
Re: NeoPixel Power Question - Costume Project
by adafruit_support_bill on Fri Oct 31, 2014 6:35 am
Power them separately as you describe from the USB ports. Then, for each of the 5 data lines, also run a ground line from the Arduino to the Neopixel strip.
by kagatoamv on Fri Oct 31, 2014 3:43 pm
Thanks! I'll give this a try.
kagatoamv
by kagatoamv on Wed Nov 12, 2014 3:14 am
Thanks again, this worked perfectly.
After figuring out the power issue, I added the RF T4 Receiver so i could switch between light "shows" and the whole thing came together surprisingly well.
kagatoamv
by adafruit_support_bill on Wed Nov 12, 2014 7:10 am
Sounds great. Don't forget to post some photos!
by kagatoamv on Mon Nov 17, 2014 8:09 pm
I'm always happy to share pictures. Here are a few from Blizzcon 2014, I'm working on a full breakdown about the costume where I will share the code I used.
I also want to shoot a video to show off the animation..
kagatoamv
by adafruit_support_bill on Mon Nov 17, 2014 9:54 pm
Awesome! Thanks for the photos.
