3.5" TFT LCD Screen Replacement
by JoshYounguk on Wed Apr 01, 2015 2:25 pm
I originally noticed a chip on the corner when I first got the screen but didn't think anything of it as the screen still worked perfectly. However today my screen decided to crack, from the chip right across the screen. :(
Where can I obtain a new screen from of which matches specification ?
Regards
Josh
JoshYounguk
Re: 3.5" TFT LCD Screen Replacement
by franklin97355 on Wed Apr 01, 2015 4:41 pm
Could you post a picture of the crack? When did you purchase the display?
franklin97355
by JoshYounguk on Wed Apr 01, 2015 4:58 pm
Thanks for the quick reply, it was purchased 4th December 2014 from UK distributor PK Sang Electronics. I don't suspect it to be under warranty back from Dec.
From the terrible picture, you can see the crack starts from the top corner and comes down across the screen. The screen it self works but with some distortion along the crack.
Thanks again,
Josh
JoshYounguk
by franklin97355 on Wed Apr 01, 2015 5:03 pm
Check with PK Sang Electronics to see if they can do anything for you.
franklin97355
by JoshYounguk on Fri Apr 03, 2015 9:50 am
So I have been in touch with SK Pang electronics. Theres nothing they can do apart from supply another whole unit at normal cost.
I didnt actually realise that the HX8357 chip is actually part of the display not on the breakout pcb. So i guess the only option is to purchase another unit.
JoshYounguk
by amarch on Mon Dec 11, 2017 8:31 pm
Actually, I am wondering about this too. I've googled the part number that is found on the screen but I can't seem to find it anywhere. Any indication of where I can get just a replacement screen with the 50-pin ZIF connector?
amarch
