This very nice monitor fails after about an hour, seems to be heat related. Used the same power supply with a 4" monitor, works fine. When the monitor fails there are streaking colors across the screen. Would like a replacement.
Peter
1280 x 800 PRODUCT ID: 1931 failed
- mediart2
Re: 1280 x 800 PRODUCT ID: 1931 failed
Actual Product ID is 1726
- Franklin97355
What power supply are you using?
- mediart2
A 12 volt 3 amp supply.
- Franklin97355
I would recommend a 5 to 7 volt power supply so as not to stress the back light.
- mediart2
Hooked up a 5 volt supply, failed after 15 minutes, black screen.
- mediart2
Might have been my error, testing it again now
- mediart2
5 volt supply worked without problems. Using 5 volts for all your monitors is the best choice? Good to know.
- Franklin97355
Glad it worked for you. I always try to go with the lowest voltage that works.
