pygame problem with adafruit-pitft on raspbian jessie
by liyue on Tue Jun 30, 2015 2:41 pm
system distribution :
- raspbian jessie;
python version:
- 2.7.9;
Adafruit PiTFT
- 2.8" Touchscreen
python code:
- while True:
# Scan touchscreen events
for event in pygame.event.get():
if(event.type is MOUSEBUTTONDOWN):
pos = pygame.mouse.get_pos()
print pos
elif(event.type is MOUSEBUTTONUP):
problem :
'pos' value not actual position and the same code works fine on raspibian wheezy
Any help, thanks!
code reference:
- http://jeremyblythe.blogspot.com/2014/0 ... asics.html
liyue
Re: pygame problem with adafruit-pitft on raspbian jessie
by adafruit2 on Wed Jul 01, 2015 12:00 pm
Does the PiTFT and touchscreen work otherwise?
adafruit2
Site Admin
by liyue on Wed Jul 01, 2015 1:08 pm
all works on rpi 2 + raspbian wheeze distribution;but not work on rpi 2+ raspbian “jessie” distribution
liyue
by adafruit2 on Wed Jul 01, 2015 1:16 pm
jeez ok it must be some change in pygame versions. dont know right now how to fix - but thx for letting us know - and if you find a solution please let us know too! :)
adafruit2
Site Admin
by ferretface on Thu Jul 23, 2015 2:41 pm
Hi Guys,
Similarly, I'm having pygame issues...this time.
I've built 2-3 of these a while ago & all was peachy. worked like a charm, kudos to the writer.
However. I'm rebuilding (my wife's jukebox) from scratch and it's all gone pear shaped (heh - fruit pun!)
Python 2.7.3 from the raspbian repository, python-pygame also.
Run the "sudo python ./radioplayer.py" command & get horrid nasty error messages which mean nothing to me as a non-programmer (no, not for a looong time, and then it was C....).
File "radioplayer.py", line 1, in <module>
import sys, pygame
File "/usr/lib/python2.7/dist-packages/pygame/__init__.py", line 99, in <module>
from pygame.base import *
ImportError: libbcm_host.so: cannot open shared object file: No such file or directory
I've tried searching on those errors, but end up wondering whether pygame & python are not in-step, but how do I find out what version of pygame I've got ?
OK - update -
Found a pygame page saying it's compatible with almost all version ps python except 2.7 (current standard apt-get), however, that's all tosh because a working one is using python 2.7. So that's a dead-end after about 4 hours of testing!
Giving up & copying the filesystem from the working one. Not the right answer though, as this instructable is now broken based on current distribution.
Unless of course - you know differently...please share if you know the secret!
I'd be very grateful if anyone might be able to point me in the right direction, thanks.
ferretface
by ferretface on Fri Jul 24, 2015 5:36 am
-Update2-
Reverted back to previous image, still same one as before, but before update & upgrade
Long story short - it's fixed but I don't know why! Worst possible answer!
I suspect that the update/upgrade process added something which disagrees with it, so my best advice is choose a suitably early raspbian (not the latest) which was released about the time of this radio project & don't upgrade it.
Sorted.
ferretface
by heine on Sat Sep 05, 2015 6:32 am
I can confirm this issue. With the Raspbian Wheezy Image (2015-05-05) everything works fine.
With a raspbian jessie Image (I built myself) it is giving a whole lot of events which show x and y values which are at least strange.
If I use "TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_print" I see the expected values. Pretty much identical to the output under wheezy.
So I suspected something in the pygame implementation shipping with jessie is broken.
But:
Under wheezy I was also able to try with python3 as it also ships a python3-pygame package. This was also working fine.
On jessie I had to build it myself (using http://askubuntu.com/questions/401342/h ... -python3-3). In the end this gives me the same problems as with using python 2.7 on jessie.
So maybe some interface pygame is using has changed in some way? I'll keep investigating.
heine
by heine on Sat Sep 05, 2015 6:52 pm
Okay, spend a lot of time today replacing the different libs involved. And I found the guilty one.
pygame isn't really doing much. It's essentially just querying SDL_GetMouseState() (see https://bitbucket.org/pygame/pygame/src ... mouse.c-46)
It's SDL. I don't know exactly what changed from wheezy to jessie. But I built SDL-1.2.15 from scratch and now my touch events are coming in as expected.
Wheezy version is 1.2.15-5, Jessie version is 1.2.15-10 so I'm too tired now to check for the differences between these two builds. As I'm building the jessie image myself I might be sticking to compiling SDL myself.
In case I have time/reason to investigate more I'll report back.
heine
by heine on Sun Sep 06, 2015 8:13 am
Submitted bug report: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=798160
For now the easiest way seems be to use the package from wheezy. Seems to work fine in jessie.
heine
by kck on Fri Dec 25, 2015 1:44 pm
Ran into this same problem and finally found this thread. Does anyone know if any progress/change has happened with the issue. I saw at the bug report referenced that the Jessie folks simply say no support for TSLIB but this now seems to make pygame useless on Jessie without some alternative solution. Is there one? Ref the comment at the end to use the package from Wheezy - what is the easiest way to do that? Thanks,
kck
by heine on Fri Dec 25, 2015 2:20 pm
since my last post raspbian jessie has officially been released. I didn't have the time to check if anything changed with this situation. But as libsdl1.2 is horribly outdated I don't see that this will come back into the official release. But I would also be interested if somebody provided a different way to have pygame touchscreen support in jessie working.
So here is how I solved this:
#enable wheezy package sources
echo "deb http://archive.raspbian.org/raspbian wheezy main
" > /etc/apt/sources.list.d/wheezy.list
#set stable as default package source (currently jessie)
echo "APT::Default-release \"stable\";
" > /etc/apt/apt.conf.d/10defaultRelease
#set the priority for libsdl from wheezy higher then the jessie package
echo "Package: libsdl1.2debian
Pin: release n=jessie
Pin-Priority: -10
Pin: release n=wheezy
Pin-Priority: 900
" > /etc/apt/preferences.d/libsdl
#install
apt-get update
apt-get -y --force-yes install libsdl1.2debian/wheezy
(the code is copied from an install script, you could of course also do these steps manually)
I hope this helps.
heine
by kck on Fri Dec 25, 2015 5:30 pm
Thank you so much for the merry Christmas present!! Fixed me up. Have a great holiday season - good wishes are the best thanks I can offer.
kck
by Turnierhamster on Sat Jan 09, 2016 7:28 am
Hi heine,
thanks for your post - after hours of searching and debugging almost all the pygame examples for my LCD Panel (ads7846/ili9341fb based) which gave me wrong readings, your solution helped me. Perhaps you should mention it to adafruit, as their tutorials at learn.adafruit.com regarding touchscreen panels might not work for other users, too.
All the best
T.
Turnierhamster
by adafruit2 on Sat Jan 09, 2016 9:14 pm
yep this is awesome. thank you for letting us know. ive added a page to each pitft tutorial
https://learn.adafruit.com/adafruit-2-4 ... ygame-tips
adafruit2
Site Admin
by jumpzero on Tue Mar 08, 2016 7:55 am
Thanks Heine and Adafruit,
I had the same problem when moving my piradiohttps://learn.adafruit.com/raspberry-pi-radio-player-with-touchscreen/overview from wheezy to jessie. Touchscreen had erractic behavior under pygame only (Ok with X).
Found this script, fixed!
But may I suggest to correct the Adafruit "PiTFT Pygame Tips" page.
Because this page was the first place were I went and read
"SDL 2.x has some serious incompatibilities with touchscreen. You can force SDL 1.2 by running a script"
I checked on my new Adafruit PiTFT jessie install:
dpkg -l | grep libsdl
ii  libsdl-image1.2:armhf                 1.2.12-5+b1                               armhf        Image loading library for Simple DirectMedia Layer 1.2, libraries
ii  libsdl-mixer1.2:armhf                 1.2.12-11+b1                              armhf        Mixer library for Simple DirectMedia Layer 1.2, libraries
ii  libsdl-ttf2.0-0:armhf                 2.0.11-3                                  armhf        TrueType Font library for Simple DirectMedia Layer 1.2, libraries
ii  libsdl1.2debian:armhf                 1.2.15-10+rpi1                            armhf        Simple DirectMedia Layer
I though, well I'm ok I'm not with sdl 2 but sdl 1.2, so my problem is something else. I went on the forum and found this solution that worked.
But the fix is to replace sdl 1.2.15-10 with 1.2.15-5 (Not sdl 2 with 1.2)
Anyway it worked fine, thanks again
Jmp0
jumpzero
