Hi everyone,
I followed the instructions I found on:
https://learn.adafruit.com/adafruit-dot ... s?view=all
but I am unclear as I have to make the wiring with the DotStar Digital LED Strip and how do I wiring to the logic level shifter (eg 74AHCT125).
It seems to me that I must use the same connection that is located on:
https://learn.adafruit.com/light-painti ... i/hardware
Can I have a wiring diagram and a circuit diagram, as clear as possible, to connect the raspberry Pi2 with DotStar Digital LED Strip.
Best regards.
Dotstar wiring with the raspberry PI2
- adafruit_support_rick
Re: Dotstar wiring with the raspberry PI2
Try this: I think this is right:
The Pi wiring matches the definition in strandtest.py, here:
https://github.com/adafruit/Adafruit_DotStar_Pi
Pin 1 on the IC is the lower left. Didn't have a DotStar strip in the Fritzing library, so I used an LPD8806 strip instead. Wiring is the same.The Pi wiring matches the definition in strandtest.py, here:
- alessandroferri
Excuse me, but I never used the Half-size breadboard, so I really do not understand how the electrical connections are in the picture. The DotStart use the same ports of LPD8806? How you connect 74AHCT125 - Quad-Level Shifter?
Best regards
Best regards
74HCT125 pin
1 - GND
2- GPIO 24
3- CI
4- GND
5- GPIO 23
6- DI
7-GND
14 - 5V
Dotstar
GND-GND
DI - 74HCT125 pin 6
CI- 74HCT125 pin 3
5V-5V
Pi Cobbler
GPIO 23 - 74HCT125 pin 5
GPIO 24 - 74HCT125 pin 2
GND-GND
1 - GND
2- GPIO 24
3- CI
4- GND
5- GPIO 23
6- DI
7-GND
14 - 5V
Dotstar
GND-GND
DI - 74HCT125 pin 6
CI- 74HCT125 pin 3
5V-5V
Pi Cobbler
GND-GND
- eliotw
Just a follow up for future users: I just wired my dotstar/rpi with according to the diagram above, and it worked!
