Electronic Animated Eyes using Teensy 3.1
Re: Electronic Animated Eyes using Teensy 3.1
by pburgess on Tue Oct 11, 2016 12:58 pm
Eek! Definitely meant Teensy. Fixed in the guide now, thanks for spotting that!
That's correct, both eyes share those 4 pins, while the 'select' wire is unique to each display. How you split those four connections can be a matter of personal preference...with thin wire, you can fit two through each via on the Teensy board before soldering. Or a two-way splice with some heat-shrink is pretty compact (image attached is a three-way splice, but same idea). Or you can cut out a small piece of a Perma-Proto board and make use of the connected pads.
pburgess
by cammi on Tue Oct 11, 2016 2:18 pm
Thank you @pburgess! Those pictures are also very helpful! :)
cammi
by woodcmiami on Wed Oct 12, 2016 5:11 pm
I constructed this several months ago and it worked so well I bought another teensy 3.2 and a couple of OLED's to make another. I am using the same code as before but now when I try to compile I get this error;
Documents/Arduino/Teensy3.1_Eyes-master/uncannyEyes/uncannyEyes.ino:460:17: warning: extra tokens at end of #ifdef directive [enabled by default]
 #ifdef IRIS_PIN && (IRIS_PIN >= 0) // Interactive iris
uncannyEyes: In function 'void frame(uint16_t)':
uncannyEyes:327: warning: comparison between signed and unsigned integer expressions
     if((t - eye[eyeIndex].blink.startTime) >= eye[eyeIndex].blink.duration) {
uncannyEyes:404: warning: comparison between signed and unsigned integer expressions
     if(s >= eye[eyeIndex].blink.duration) s = 255;   // At or past blink end
I tried downloading the code again and get the same errors. Any ideas on how to get this to compile like it did before?
woodcmiami
by michaelmeissner on Wed Oct 12, 2016 6:59 pm
You probably used an older Teensydunio, which used an older compiler. Recent versions of teensydunio also now enable more warnings.
BTW, the code is incorrect. The compiler is correct in flagging it.
Change:
to:
#if defined(IRIS_PIN) && (IRIS_PIN >= 0) // Interactive iris
michaelmeissner
by michaelmeissner on Wed Oct 12, 2016 7:28 pm
BTW, with the 1.44" TFT screens, I have found that the 12 LED neopixel ring is just the perfect size to be around the eye, and you can use a 22mm cabochons for inside of the ring. You would need to put the neopixel update code in the frame function, rather than in loop.
I have my Teensy 3.6 running with 2 third party TFT screens and 2 12-LED neopixels running my normal random patterns. I need to clean it up, because my current incarnation is somewhat glitchy.
Ultimately, I hope to marry the prop shield's motion sensors with the eyes.
michaelmeissner
by cammi on Fri Oct 21, 2016 12:09 pm
I'm looking to modify uncannyEyes so that the eyes can also express the emotion where the eyes would go from being "O_O" and pull up to be "^_^" (If my emoticon analogy makes sense.) I'd like this to do it on its own autonomously and would still like it support autoblinking as the code already does. So, my target behavior is it being able to randomly animate between eyes open "O_O", eyes closed "-_-", and smiling eyes "^_^"
I was looking at the uncannyEyes.ino and I was thinking of creating another data struct similar to eyeBlink and implement it similar to how eyeBlink is. I.e.,
typedef struct {
  int8_t   pin;       // Optional button here for indiv. wink
  uint8_t  state;     // NOSMILEBLINK/ENSMILEBLINK/DESMILEBLINK
  int32_t  duration;  // Duration of blink state (micros)
  uint32_t startTime; // Time (micros) of last state change
} eyeSmile;
But would just modifying the upper and lower lid threshold enough such that it could pull up make it look like "^_^"?
Am I going down an appropriate line of thought and/or does anyone have any other suggestions?
cammi
by cmv on Fri Oct 21, 2016 1:06 pm
I've configured the eyes and they look great in the default automatic mode. When the analog joystick control is added, however, the eyes appear very shakey. I'm assuming this is happening because of noise from the joystick or the framestack updating from analog input. Is there a filter or other method that could be applied to lessen this shake?
cmv
by pburgess on Fri Oct 21, 2016 1:29 pm
Ideas for reducing joystick noise are covered in this prior post:
viewtopic.php?f=47&t=80947&p=457494&hilit=eyes+joystick#p457494
pburgess
by cmv on Tue Nov 08, 2016 10:40 am
Thanks for the help!
As a follow-up, is there a way to configure the code to accept input from a USB joystick connected to the computer rather than wired to the board?
cmv
by pburgess on Tue Nov 08, 2016 10:49 am
As written, no. There's an option to interface an analog joystick directly to the Teensy, but otherwise you'd need to implement something yourself, perhaps reading positions from a serial connection.
pburgess
by michaelmeissner on Tue Nov 08, 2016 1:11 pm
Well the new Teensy 3.6 does have pins for USB host support, but I suspect we are several months away from it being usable for things like USB joysticks.
Of course, if you were to roll up your sleeves, dive in and do the necessary work (learning about USB protocols in the process), it will get done sooner. Otherwise, you will need to wait until somebody else does it.
michaelmeissner
by TheElectronicWosky on Sat Jun 03, 2017 1:22 am
Hi, I was trying to replicate the project, but as you can see in the picture, the screen doesn't work as intended. The cables are short, soldering is good, I don't know what else it could be.
I'm using a Teensy 3.2, and the latest Arduino IDE (1.8.2)
TheElectronicWosky
by pburgess on Sun Jun 04, 2017 11:53 pm
Make sure you've enabled the right code for OLED vs TFT. Looks like it might be turning the screen on but then sending the wrong init sequence for the display.
If that's not it, some clear photos of all the wiring maybe helpful.
pburgess
by TheElectronicWosky on Mon Jun 05, 2017 1:11 pm
OLED is selected on the code (yes, I downloaded the library)
Here is the pin connection
SI/MOSI (Green) ===> Pin 11
CL/SCLK (Yellow) ===> Pin 13
RST (White) ===> Pin 8
DC (Blue) ===> Pin 7
OC (Red & Brown) ===> Pins 6/5 (I changed them in the code)
And some images, not the of best quality tho.
http://imgur.com/a/txTOd
TheElectronicWosky
by michaelmeissner on Wed Jun 07, 2017 11:09 pm
I've been busy, and I haven't been doing much in terms of Teensy.
IIRC, the animated eyes program runs too fast for the OLED displays. Back a few months ago, I was running it on the Teensy 3.2/3.5/3.6. I discovered that I had to reduce the Teensy speed to 24Mhz in order to run the displays with the Adafruit OLED display. With another OLED display that I got from Newhaven, I could usually run it at 48Mhz. Even at 24Mhz, it would glitch some times.
To change the speed, goto the Tools menu in the IDE title bar, select CPU speed, and then select 24Mhz.
The 2 different TFT displays I tried (Adafruit and a no-name display from ebay), I could run the Teensy 3.6 at 240 Mhz (the fastest overclock speed). Note, with the TFT displays, there are two gotchas:
  • Teensy hasn't picked up the lastest Adafruit_ST7735 that has the support for the 128x128 displays. You need to not load the PJRC version, and instead load the version from Adafruit.
  • You really want to use the 5 special SPI CS (9, 10, 15/A1, 20/A6, and 21/A7) pins for the maximum speed. I use 15/A1 for DC, 9 for the left eye, 10 for the right eye, and 8 for reset.
michaelmeissner
