Electronic Animated Eyes using Teensy 3.1
Re: Electronic Animated Eyes using Teensy 3.1
by pburgess on Fri Jun 09, 2017 12:08 am
Wiring looks good and I still haven't been able to reproduce the issue nor see any likely culprit.
To confirm some assumptions:
  • You've run the normal SSD1351 'test' example (with dc/cs/rst pins adjusted to match wiring) and this works?
  • You did NOT install the Adafruit_GFX or Adafruit_SSD1531 libraries offered by the Teensyduino installer? Use the Arduino Library Manager instead or fetch the code from Github. The Teensyduino versions may break something. Remove them if that's what you installed.
  • You're running the plain vanilla Uncanny Eyes sketch linked to in the guide, not anyone's custom variant just yet, correct?
  • Using the default human eye?
  • Teensy speed set at 72 MHz?
If it's not any of that, please elaborate on your system setup: OS, IDE version, etc. (e.g. Windows 10, Arduino IDE 1.8.2, Teensyduino 1.35 installer)
pburgess
by TheElectronicWosky on Sun Jun 11, 2017 10:32 pm
Now everything is working fine, I set the teensy to 16MHz, and works perfectly.
tho, now the teensy doesn't appear on ports, and I need to use an FTDI board to upload the code, any ideas why this happened?
anyways, thanks for all the help you gave me.
TheElectronicWosky
by pburgess on Sun Jun 11, 2017 11:29 pm
When running the Teensy board below 24 MHz, it's normal for there to be no serial port (since it can't handle USB timing at these lower speeds). It's not necessary to pick a port when uploading to this board over USB; the Teensy Loader application and bootloader kind of do their own thing. Port's only needed if using Serial.print().
With the OLED displays, you can run the Teensy board up to 72 MHz (and have USB serial if you need it).
pburgess
by TheElectronicWosky on Mon Jun 12, 2017 12:03 am
oh, okay.
I tried to use 72mhz but sadly, it doesn't work.
TheElectronicWosky
by michaelmeissner on Wed Jun 14, 2017 8:19 am
As I said earlier, I could only get the Adafruit displays to run at 24Mhz (which is the slowest speed where USB serial will still work). I could not get them to work at 48Mhz. And a different brand of the OLED displays (newhaven), I could run at 48Mhz, but not 72Mhz.
So, I suspect sample variation, and you just have to test the display to see what works for you. It may be the 24Mhz was a particular run of the displays, and another batch might be slower or faster.
michaelmeissner
by alan_hansen on Mon Jun 19, 2017 7:59 pm
If the displays are freezing or displaying garbage, then edit the SPI clock speed, highly dependent on cable length.
SPISettings settings(19000000, MSBFIRST, SPI_MODE3); // Teensy 3.1 max SPI
Try values from 15000000 to 20000000
I have a Teensy 3.2 running 120MHz overclocked
And not all 5V power supplies are equal, solder a 100uF 6V on Teensy 5V buss
alan_hansen
by TheElectronicWosky on Fri Jun 23, 2017 8:49 pm
So I'm trying to upload the dragon eye example, and it gives this error
dragonEye.h:15637: error: narrowing conversion of '-1' from 'int' to 'uint16_t {aka short unsigned int}' inside { } [-Wnarrowing]
0X007F, 0X007F, 0X007F, 0X007F, 0X007F, 0X007F, 0X007F, 0X007F, };
TheElectronicWosky
by pburgess on Fri Jun 23, 2017 8:54 pm
***EDIT*** ***UPDATE*** This is no longer necessary, though there is ZERO harm in doing it this way if that's what you've got installed. The code will compile now in the latest Arduino IDE & Teensyduino just fine. Make sure to fetch the current Adafruit eye code from Github as a starting point. If you're using any other fork or variant, it might not have the necessary fix yet.
If you plan to use the dragon eyes (or any of the non-default, non-human eyes), you should install the Arduino IDE version 1.8.1 and then run the Teensyduino 1.35 installer atop this. This is a temporary situation due to a bug in the latest Teensy compiler preventing arrays over 32K…guide will be updated when this is fixed. If you want the latest IDE for other projects, it’s valid and possible to have multiple Arduino IDE installs on your system, just need to give each a unique name.
IDE 1.8.1 can be downloaded here: https://www.arduino.cc/en/Main/OldSoftw ... s#previous
And Teensyduino 1.35 here: https://forum.pjrc.com/threads/41493-Te ... -35-Beta-2
pburgess
by TheElectronicWosky on Tue Jun 27, 2017 9:47 pm
I'm such a dummy sometimes (ok fine, most of the times). Thank you guys so much for being so nice nwn.
last question (I hope so), I'm trying to do a Dragon/demon-like eyes, and I successfully changed the iris color, but I fail at the pupil.
So, I noticed that the dragon and g0at (banned word, why tho?) eyes have a pupil map, where it is supposed to go? I tried both of this options but none of them worked for me.
a) python tablegen.py DragonEye/sclera.png DragonEye/iris.png DragonEye/upper.png DragonEye/lower.png DragonEye/PupilMap 160 > DragonEye.h
b) python tablegen.py DragonEye/sclera.png DragonEye/iris.png DragonEye/upper.png DragonEye/lower.png 160 DragonEye/PupilMap > DragonEye.h
c) Add your reply here.
Again, thanks a lot.
TheElectronicWosky
by pburgess on Wed Jun 28, 2017 3:19 am
Howdy.
Someone spotted a bug recently in the eye code, now fixed, and it turns out it can be compiled in the latest Arduino IDE & Teensyduino if that's what you've got. No harm though in using the 1.8.1/1.35 combo. All good, whichever version, just be sure to download the latest eye code (including the converter script) from Github.
Converting the dragon eye is SUPER kludgey and horrible, I apologize in advance for this...
First, copy the dragon pupil map image to the same directory containing the 'tablegen' script, and call it 'pupilMap.png'. i.e. like this:
cp dragonEye/dragonPupilMap.png pupilMap.png
Then, when doing the conversion, use a *negative* iris size to tell the script it should use the pupilMap image (the filename is hardcoded and not specified on the command line):
python tablegen.py dragonEye/sclera.png dragonEye/iris.png dragonEye/upper.png dragonEye/lower.png -160 > myNewEye.h
pburgess
by novice516 on Sun Jul 02, 2017 7:02 pm
I am working on the Animated Eyes using the teensy 3.2. When I try to upload the code which was posted on the animated eyes learning page https://learn.adafruit.com/animated-ele ... 1/software the software compiles, but when I try to upload it, teensy informs me that the code is too large. I did not modify the code other than as instructed to work with the TTF - thus commenting out the OLE and un-commenting the TTF in lines 28-29. I am using the arduino 1.81 IDE and did not load the libraries listed like GFX as instructed when i installed the teensyduino 1.35 beta #2.
Thank you in advance.
Novice,
Tom
novice516
by pburgess on Sun Jul 02, 2017 7:13 pm
Which of the eye designs are you using, and what's the "Optimize" setting in the Tools menu?
pburgess
by Snufkin52 on Tue Jul 11, 2017 7:49 pm
Hello, I need your help.
I try to create Eyes, using Teensy 3.1, but i couldn't buy 1.44'' TFT display, i bought TFT Display 126x160.
So, when i start project on board, i sow this picture :
Part of display working current, but it is endless & cycled image.
And eye is stretched.
May be you can help me solve this problem?
Snufkin52
by pburgess on Wed Jul 12, 2017 6:05 pm
The code doesn't work with 160x128 displays, but a couple of threads have explored the possibility of using a 128x128 pixel section of the screen. No guarantees, there are many ever-so-slightly different versions of these screens, but these might offer some hints on adapting the code:
viewtopic.php?f=22&t=81236&p=542009&hilit=eyes+160#p541329
viewtopic.php?f=22&t=81236&start=20
pburgess
by novice516 on Sat Jul 15, 2017 12:33 am
I am using the "smallest code with LTO" and the default eye setting
novice516
