Is it possible to emulate mouse wheel scrolling with a finger using the 2.8" Capacitive Touchscreen (#2423) and a Raspberry Pi3. If so, what needs to be done to make it happen?
Rod
2.8 Capacitive Touchscreen & Mousewheel Scroll Emulation
- rodsten
- asteroid
Re: 2.8 Capacitive Touchscreen & Mousewheel Scroll Emulation
Perhaps a slider; this code runs ok on an UNO (not sure about Pi3). Possibly could also use up, down arrows depending on what you are trying to do.
* Slider control
* For Adafruit 2.8" TFT LCD - capacitive.
* Any of the four screen rotations may be used.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_FT6206.h>
// Default values for Adafruit shield v2.
#define TFT_DC 9
#define TFT_CS 10
// The FT6206 uses hardware I2C (SCL/SDA)
Adafruit_FT6206 ctp = Adafruit_FT6206();
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// Common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define Slider_X 170
#define Slider_Y 40
#define Slider_W 5
#define Slider_H 170
#define Thumb_W 50
#define Thumb_H 25
#define Thumb_X Slider_X - Thumb_W/2 + 2
#define initThumb_Y 125
TS_Point p;
int x, y, y1;
int sliderValue = 0;
int Thumb_Y = 0;
char sliderValueStr[5];
// Rotations 0,2 = portrait : 0->USB=right,upper : 2->USB=left,lower
// Rotations 1,3 = landscape : 1->USB=left,upper : 3->USB=right,lower
byte rotation = 1; //(0->3)
void showSliderValue(int value)
sprintf(sliderValueStr,"%03d",value);
tft.setCursor(30,30);
tft.setTextColor(WHITE, BLUE);
tft.setTextSize(3);
tft.print(sliderValueStr);
void showOrigin() {
tft.setCursor(0, 0);
tft.setTextColor(WHITE);
tft.setTextSize(2);
tft.print("o");
void sliderHandler() {
sliderValue = (tft.height() - y) - (tft.height()-(Slider_Y+Slider_H-Thumb_H));
if (sliderValue < 0) sliderValue = 0;
showSliderValue(sliderValue);
// erase previous thumb by redrawing with background color
tft.drawRect(Thumb_X, y1, Thumb_W, Thumb_H, BLUE);
// then draw new thumb
tft.drawRect(Thumb_X, y, Thumb_W, Thumb_H, WHITE);
tft.fillRoundRect(Slider_X, Slider_Y, Slider_W, Slider_H, 2, WHITE);
tft.begin();
if (! ctp.begin()) { // pass in 'sensitivity' coefficient
Serial.println("Couldn't start FT6206 touchscreen controller");
while (1);
tft.setRotation(rotation);
tft.fillScreen(BLUE);
showOrigin();
Thumb_Y = initThumb_Y;
y = Thumb_Y + Thumb_H/2;
y1 = y;
sliderHandler();
if (!ctp.touched()) {
return;
p = ctp.getPoint();
switch (rotation) {
case 0:
x = 240 - p.x;
y = 320 - p.y;
break;
case 1: // p.x, p.y reversed
x = 320 - p.y;
y = p.x;
break;
case 2:
x = p.x;
y = p.y;
break;
case 3: // p.x, p.y reversed
x = p.y;
y = 240 - p.x;
break;
Thumb_Y = y - Thumb_H/2;
if(x > Thumb_X && x < (Thumb_X + Thumb_W)) {
if(y > Thumb_Y && y < (Thumb_Y + Thumb_H)) {
if(Thumb_Y < Slider_Y){
y = Slider_Y;
else if((Thumb_Y + Thumb_H) > (Slider_Y+Slider_H)){
y = (Slider_Y+Slider_H)-Thumb_H;
sliderHandler();
y1 = y;
