Supernova_poi
Re: Supernova_poi
by KasHoogeveen on Mon Jan 23, 2017 3:56 pm
laazarus wrote:just tested with the remote from my sony tv. just copied codes straight out of serial monitor and pasted into the code. turns out my tv remote has a better emmitter than the little adafruit one.
I think I got it.
I'm using a IR SENSOR - TSOP38238 which is working fine while using the simple irrecv commands. But with the supernova there's something going on with how sensitive the IR receiver is.
I've soldered another brand of ir receiver and now it's working like a charm! (woohoo) but I'm still wondering if a simple resistor could filter out the noise generated from the ir receiver.
Anyway, if that won't work I need to get a second receiver like the one I have now, which is working, and solder that on number two.
KasHoogeveen
Re: Supernova_poi
by laazarus on Mon Jan 23, 2017 4:30 pm
I'm using the TSOP38238. may be yours was a faulty and not performing correctly. important thing is your poi are working
laazarus
Re: Supernova_poi
by KasHoogeveen on Mon Jan 23, 2017 4:37 pm
laazarus wrote:I'm using the TSOP38238. may be yours was a faulty and not performing correctly. important thing is your poi are working
That would mean both are faulty? Could be.. Anyway. The poi is working. Thanks.
KasHoogeveen
Re: Supernova_poi
by DJ Namaste on Tue Nov 07, 2017 2:44 pm
Hi, I am having the same problem with my RGB led controller remote. I have entered the IR codes I get from the serial monitor so I know it is reading them correctly but they dont control the poi. Any idea why? If the codes are printing into the serial monitor it should control the poi. When I use a different IR example the board and IR receiver and remote are working together.
DJ Namaste
Re: Supernova_poi
by DJ Namaste on Wed Nov 08, 2017 1:39 pm
Also, I am using an Adafruit Trinket MO for this. It does work with each case specifically called by remote but when it is coded as the standard sketch here https://github.com/adafruit/Kinetic_POV ... va_poi.ino, it does not work. Any ideas why?
DJ Namaste
Re: Supernova_poi
by DJ Namaste on Thu Nov 09, 2017 1:09 am
I rearranged some things in the code and it is working now with my remote and it is using a similar structure. I dont understand why the code works for some using the sketch in the link I posted before. This one is working now though.
  POV IR Supernova Poi sketch.  Uses the following Adafruit parts
  (X2 for two poi):
  - Teensy 3.2 (required - NOT compatible w/AVR-based boards)
  - 2200 mAh Lithium Ion Battery https://www.adafruit.com/product/1781
  - LiPoly Backpack https://www.adafruit.com/product/2124
  - 144 LED/m DotStar strip (#2328 or #2329)
    (ONE METER is enough for TWO poi)
  - Infrared Sensor: https://www.adafruit.com/product/157
  - Mini Remote Control: https://www.adafruit.com/product/389
    (only one remote is required for multiple poi)
  Needs Adafruit_DotStar library: github.com/adafruit/Adafruit_DotStar
  Also, uses version of IRremote library from the Teensyduino installer,
  the stock IRremote lib will NOT work here!
  This is based on the LED poi code (also included in the repository),
  but AVR-specific code has been stripped out for brevity, since these
  mega-poi pretty much require a Teensy 3.X.
  products from Adafruit!
  Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
  MIT license, all text above must be included in any redistribution.
  See 'COPYING' file for additional notes.
#include <Arduino.h>
#include <Adafruit_DotStar.h>
//#include <avr/power.h>
//#include <avr/sleep.h>
#include <IRremote.h>
#include <SPI.h>
typedef uint16_t line_t;
// CONFIGURABLE STUFF ------------------------------------------------------
#include "nicksstaff.h" // Graphics data is contained in this header file.
// It's generated using the 'convert.py' Python script.  Various image
// formats are supported, trading off color fidelity for PROGMEM space.
// Handles 1-, 4- and 8-bit-per-pixel palette-based images, plus 24-bit
// truecolor.  1- and 4-bit palettes can be altered in RAM while running
// to provide additional colors, but be mindful of peak & average current
// draw if you do that!  Power limiting is normally done in convert.py
// (keeps this code relatively small & fast).
// Ideally you use hardware SPI as it's much faster, though limited to
// specific pins.  If you really need to bitbang DotStar data & clock on
// different pins, optionally define those here:
#define LED_DATA_PIN  0
#define LED_CLOCK_PIN 2
// Empty and full thresholds (millivolts) used for battery level display:
#define BATT_MIN_MV 3350 // Some headroom over battery cutoff near 2.9V
#define BATT_MAX_MV 4000 // And little below fresh-charged battery near 4.1V
boolean autoCycle = false; // Set to true to cycle images by default
uint32_t CYCLE_TIME = 12; // Time, in seconds, between auto-cycle images
int RECV_PIN = 4;
IRrecv irrecv(RECV_PIN);
decode_results results;
// Adafruit IR Remote Codes:
//   Button       Code         Button  Code
//   VOL-:        0xFD00FF     0/10+:  0xFD30CF
//   Play/Pause:  0xFD807F     1:      0xFD08F7
//   VOL+:        0xFD40BF     2:      0xFD8877
//   SETUP:       0xFD20DF     3:      0xFD48B7
//   STOP/MODE:   0xFD609F     4:      0xFD28D7
//   UP:          0xFDA05F     5:      0xFDA857
//   DOWN:        0xFDB04F     6:      0xFD6897
//   LEFT:        0xFD10EF     7:      0xFD18E7
//   RIGHT:       0xFD50AF     8:      0xFD9867
//   ENTER/SAVE:  0xFD906F     9:      0xFD58A7
//   Back:        0xFD708F
#define BTN_BRIGHT_UP    0x8503705D   //|| 16187647
#define BTN_BRIGHT_DOWN  0xDEB0C861 //|| 16220287
#define BTN_RESTART      0xA2672345//|| 16236607 // bttn on
#define BTN_BATTERY      0xCE1972FD //|| 16203967 / unassigned
#define BTN_FASTER       0xFD805F
#define BTN_SLOWER       0xFDB04F
#define BTN_OFF          0xD4DD0381
#define BTN_PATTERN_PREV 0x78CDA4DD
#define BTN_PATTERN_NEXT 0xE85952E1
#define BTN_AUTOPLAY     0XFD906F
#define BTN_NONE       -1
//#define BTN_WHITE        2611188417 || 16244767
//#define BTN_RED          3898168033 || 16195807
//#define BTN_GREEN        2026743005 || 16228447
//#define BTN_BLUE         2724668229 || 16212127
//#define BTN_ORANGE        3556612737 || 16191727
#if defined(LED_DATA_PIN) && defined(LED_CLOCK_PIN)
// Older DotStar LEDs use GBR order.  If colors are wrong, edit here.
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS,
  LED_DATA_PIN, LED_CLOCK_PIN, DOTSTAR_BGR);
#else
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS, DOTSTAR_BGR);
#endif
void     imageInit(void),
         IRinterrupt(void);
uint16_t readVoltage(void);
  strip.begin(); // Allocate DotStar buffer, init SPI
  strip.clear(); // Make sure strip is clear
  strip.show();  // before measuring battery
  imageInit();   // Initialize pointers for default image
  irrecv.enableIRIn(); // Start the receiver
// GLOBAL STATE STUFF ------------------------------------------------------
uint32_t lastImageTime = 0L, // Time of last image change
         lastLineTime  = 0L;
uint8_t  imageNumber   = 0,  // Current image being displayed
         imageType,          // Image type: PALETTE[1,4,8] or TRUECOLOR
        *imagePalette,       // -> palette data in PROGMEM
        *imagePixels,        // -> pixel data in PROGMEM
         palette[16][3];     // RAM-based color table for 1- or 4-bit images
line_t   imageLines,         // Number of lines in active image
         imageLine;          // Current line number in image
volatile uint16_t irCode = BTN_NONE; // Last valid IR code received
const uint8_t PROGMEM brightness[] = { 15, 31, 63, 127, 255 };
uint8_t bLevel = sizeof(brightness) - 1;
// Microseconds per line for various speed settings
const uint16_t PROGMEM lineTable[] = { // 375 * 2^(n/3)
  1000000L /  375, // 375 lines/sec = slowest
  1000000L /  472,
  1000000L /  595,
  1000000L /  750, // 750 lines/sec = mid
  1000000L /  945,
  1000000L / 1191,
  1000000L / 1500  // 1500 lines/sec = fastest
uint8_t  lineIntervalIndex = 3;
uint16_t lineInterval      = 1000000L / 750;
void imageInit() { // Initialize global image state for current imageNumber
  imageType    = images[imageNumber].type;
  imageLines   = images[imageNumber].lines;
  imageLine    = 0;
  imagePalette = (uint8_t *)images[imageNumber].palette;
  imagePixels  = (uint8_t *)images[imageNumber].pixels;
  // 1- and 4-bit images have their color palette loaded into RAM both for
  // faster access and to allow dynamic color changing.  Not done w/8-bit
  // because that would require inordinate RAM (328P could handle it, but
  // I'd rather keep the RAM free for other features in the future).
  if(imageType == PALETTE1)      memcpy_P(palette, imagePalette,  2 * 3);
  else if(imageType == PALETTE4) memcpy_P(palette, imagePalette, 16 * 3);
  lastImageTime = millis(); // Save time of image init for next auto-cycle
void nextImage(void) {
  if(++imageNumber >= NUM_IMAGES) imageNumber = 0;
  imageInit();
void prevImage(void) {
  imageNumber = imageNumber ? imageNumber - 1 : NUM_IMAGES - 1;
  imageInit();
// MAIN LOOP ---------------------------------------------------------------
  uint32_t t = millis(); // Current time, milliseconds
  if(autoCycle) {
    if((t - lastImageTime) >= (CYCLE_TIME * 1000L)) nextImage();
    // CPU clocks vary slightly; multiple poi won't stay in perfect sync.
    // Keep this in mind when using auto-cycle mode, you may want to cull
    // the image selection to avoid unintentional regrettable combinations.
 while (irrecv.decode(&results == 0));
    imageswitch();
if  (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
        switch(results.value) {
         case BTN_BRIGHT_UP:
          if(bLevel < (sizeof(brightness) - 1))
            strip.setBrightness(brightness[++bLevel]);
          break;
         case BTN_BRIGHT_DOWN:
          if(bLevel)
            strip.setBrightness(brightness[--bLevel]);
          break;
         case BTN_FASTER:
          CYCLE_TIME++;
          if(lineIntervalIndex < (sizeof(lineTable) / sizeof(lineTable[0]) - 1))
           lineInterval = lineTable[++lineIntervalIndex];
          break;
         case BTN_SLOWER:
         if(CYCLE_TIME > 0) CYCLE_TIME--;
          if(lineIntervalIndex)
           lineInterval = lineTable[--lineIntervalIndex];
          break;
         case BTN_RESTART:
          imageNumber = 0;
          imageInit();
          break;
         case BTN_OFF:
          strip.setBrightness(0);
          break;
         case BTN_PATTERN_PREV:
          prevImage();
          break;
         case BTN_PATTERN_NEXT:
          nextImage();
          break;
         case BTN_AUTOPLAY:
          autoCycle = !autoCycle;
          break;
      results.value = BTN_NONE;
  strip.show(); // Refresh LEDs
  lastLineTime = t;
void IRinterrupt() {
    Serial.println(results.value, DEC);
    irrecv.resume(); // Receive the next value
void imageswitchs() {
 switch(imageType) {
    case PALETTE1: { // 1-bit (2 color) palette-based image
      uint8_t  pixelNum = 0, byteNum, bitNum, pixels, idx,
              *ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS / 8];
      for(byteNum = NUM_LEDS/8; byteNum--; ) { // Always padded to next byte
        pixels = *ptr++;                       // 8 pixels of data (pixel 0 = LSB)
        for(bitNum = 8; bitNum--; pixels >>= 1) {
          idx = pixels & 1; // Color table index for pixel (0 or 1)
          strip.setPixelColor(pixelNum++,
            palette[idx][0], palette[idx][1], palette[idx][2]);
      break;
    case PALETTE4: { // 4-bit (16 color) palette-based image
      uint8_t  pixelNum, p1, p2,
              *ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS / 2];
      for(pixelNum = 0; pixelNum < NUM_LEDS; ) {
        p2  = *ptr++;  // Data for two pixels...
        p1  = p2 >> 4; // Shift down 4 bits for first pixel
        p2 &= 0x0F;    // Mask out low 4 bits for second pixel
          palette[p1][0], palette[p1][1], palette[p1][2]);
          palette[p2][0], palette[p2][1], palette[p2][2]);
      break;
    case PALETTE8: { // 8-bit (256 color) PROGMEM-palette-based image
      uint16_t  o;
      uint8_t   pixelNum,
               *ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS];
      for(pixelNum = 0; pixelNum < NUM_LEDS; pixelNum++) {
        o = *ptr++ * 3; // Offset into imagePalette
        strip.setPixelColor(pixelNum,
          imagePalette[o],
          imagePalette[o + 1],
          imagePalette[o + 2]);
      break;
    case TRUECOLOR: { // 24-bit ('truecolor') image (no palette)
      uint8_t  pixelNum, r, g, b,
              *ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS * 3];
        r = *ptr++;
        g = *ptr++;
        b = *ptr++;
        strip.setPixelColor(pixelNum, r, g, b);
      break;
DJ Namaste
Re: Supernova_poi
by DJ Namaste on Sat Nov 11, 2017 2:44 pm
After checking the outcome of the changes made, the patterns are slowed down. If I run the original sketch without IR input, the patterns run faster. When I alter it so it does receive IR input, the patterns are slower. Anyone? Anyone? :/
DJ Namaste
Re: Supernova_poi
by laazarus on Mon Nov 13, 2017 9:23 am
I'm not much of a coder (not at all really) but I can try and throw a few ideas into the mix. when you say slower do you mean that it is slower producing each column of an image so every thing looks stretched out, or slower changing between images so the timing goes out of sync with music?
The trinket m0 doesn't run as fast or have some of the more advanced features as the teensy the project was originally designed for so it could just be a lack of horse power to handle ir and imaging.
It would be nice to get this working well on cheaper hardware, I've lost count of the number of people who've asked me to build them a set but then decided not to go ahead when they hear the cost.
update:
Just been looking at the pin outs for the M0 and your code. could be that in practice the code to physical pin mapping is a bit different but by the looks of it the hardware SPI support on the M0 is on pins 3 and 4 where as you're using 0 and 2. if this is the case could shifting on to the hardware spi take a bit of load off the processor. failing that there is also the on board dotstar led. what happens if you take clock and data direct from its pins? (7 and 8)
laazarus
Re: Supernova_poi
by DJ Namaste on Mon Nov 13, 2017 12:01 pm
You were right about the hardware SPI pins. I thought I read the hardware spi pins were 0 and 2. It now runs fast at the right speed using pins 3 and 4 but the flash after each display is still there. I think the first 32 pixels are dumping remaining data to the rest of the leds and it causes random flashing. I dont know how to get rid of it. It is so fast that it is kind of unnoticeable but it is annoying. Also, about the IR remote: Does the original example sketch work on github? I can not get my remote to work with the code unless I get rid of this part:
if(results.value != BTN_NONE) {
      if(!strip.getBrightness()) { // If strip is off...
        // Set brightness to last level
        strip.setBrightness(brightness[bLevel]);
        // and ignore button press (don't fall through)
        // effectively, first press is 'wake'
      } else {
DJ Namaste
Re: Supernova_poi
by DJ Namaste on Mon Nov 13, 2017 12:09 pm
https://youtu.be/Bj14VqTYr_U
This video shows the single dot running down the strip and the flash that happens in between each scan of the image.
DJ Namaste
Re: Supernova_poi
by DJ Namaste on Mon Nov 13, 2017 12:39 pm
When I reconnected the pins I changed the IR pin and now the sketch works with the IR remote. Odd that it worked before if I modified the sketch.
DJ Namaste
Re: Supernova_poi
by laazarus on Thu Jan 18, 2018 1:19 pm
DJ Nameste,
Just curious, when you put together your trinket m0 based poi did you include the lipoly back pack and have them self contained or are you needing to charge batteries externally?
I'm looking to put a couple more sets together for friends but they really need to be self contained. ideally i'd like to use the cheaper boards if possible but if they cant work with the charger board I'll stick with the trinket pro's
laazarus
Re: Supernova_poi
by cynikal on Mon Feb 19, 2018 2:12 pm
Have all the parts on their way, was wondering:
- Does the bottom end of the POI, where i'm presuming the usb charger port is (and is this an incorrect assumption), have any kind of closure/end-cap?? When spinning the assembled POI, how does the whole set of parts not just fly out of the tube (due to centrifugal force) if left open? I read and re-read the instructions and don't see this being addressed nor see anything clear in the pictures to stop this from happening ? Is it just held-in place because of glued and that end is left open simply?
- The placement of the IR sensor, it seems to me that only one side of the POI would be "reactive" (usable by) to the remote, no? Unless i'm just not understanding how IR signals works/travel (do they bounce off walls, so it doesn't matter what side the sensor is on as long as it's facing outward). And if this indeed would be an issue, is it possible to somehow wire two IR sensors in parallel, one on each side of the POI? My impression is that the remote should be useful by a second person while the POI is in use (spinning around) instead of just white it's being held still no?
- It's not clear whether the white wire to/from the switch/backpack is going to need to be the thicker (smaller gauge #) or the thinner (higher guage #) wire ? Is this going to be carrying the full amount of current the POI load uses back and forth, or this only used for signaling to the backpack?
cynikal
Re: Supernova_poi
by cynikal on Mon Feb 19, 2018 5:02 pm
cynikal wrote:- Does the bottom end of the POI, where i'm presuming the usb charger port is (and is this an incorrect assumption), have any kind of closure/end-cap?? When spinning the assembled POI, how does the whole set of parts not just fly out of the tube (due to centrifugal force) if left open? I read and re-read the instructions and don't see this being addressed nor see anything clear in the pictures to stop this from happening ? Is it just held-in place because of glued and that end is left open simply?
Nevermind this part of the question, it looks like i had this assumption backwards, and the switch is on the bottom, along with battery, and the leash holes are at the top, where the teensy/usb port is. This makes more sense as you'd want the weight at the outward (bottom end) where the battery is.
Still unsure about the IR sensor effectiveness on the side opposite where the sensor is pointing to and about the white wire to/from the switch.
cynikal
Re: Supernova_poi
by cynikal on Sat Feb 24, 2018 12:44 pm
Ok i've built them successfully (at least from an electronics working point of view, though i haven't done the assembly yet and didn't follow the steps in the recommended order and tweaked some other things as i went). So I can now answer my own questions somewhat:
cynikal wrote:Have all the parts on their way, was wondering:
I tested this with indirect line of sight, maybe others already know but it seems the infrared "signals" from the remote seem to bounce off things and so a direct line of sight is not necessary.. but still i WAS able to get the two POI out of sync (one POI would get a command from the remote and the other didn't).. i haven't assembled them in a polycarb tube yet, perhaps that will assist with the "reflections" of the infrared though? For now i'm happy with how responsive the remote is (once i realized that the remote came with a plastic insulator between the battery and the contacts of the remote (for shipping reasons), i just presumed the remote would work out of the box and started troubleshooting the arduino code only to realize though it came with a battery it was't yet "enabled" until you pull the plastic tab out :-)
cynikal wrote:- It's not clear whether the white wire to/from the switch/backpack is going to need to be the thicker (smaller gauge #) or the thinner (higher guage #) wire ? Is this going to be carrying the full amount of current the POI load uses back and forth, or this only used for signaling to the backpack?
Not sure about this, nor the total amount of current that would need to go across that wire. The recommended switch is only rated for 0.3 amps and that seems small but i guess it's not continuous (lot of pulsing?). In any case, i didn't want to run another pair of wiring back all the way up to past the battery like the guide does, so i am relocating the switch nearer at the teensy/lipo-backpack end (where i now realize the leash also is).. i have a 3d printer so am going to re-design the end-cap for the USB plug/light/and switch end myself in solidworks (also incorporate maybe to line up with the leash holes, so this cap doesn't need to be glued and the assembly can be removed), and will as such make the battery end-cap solid instead (this WILL be glued in place using the E6000 glue). Still haven't received my polycarbonate tube a week after ordering it tho :-/ otherwise maybe i'd have assembled this thing by now too!
cynikal
