Hi!
Recently, i buy a Adafruit 16x2 Character LCD + Keypad for Raspberry Pi (https://learn.adafruit.com/adafruit-16x ... i/overview) for my raspberry based projects.
Could this plate run with an arduino uno ?
What can i do to adapt it for the Uno ?
Thx
Adafruit 16x2 Character LCD + Keypad for Raspberry Pi => Ard
- Gerlin
- adafruit_support_rick
Re: Adafruit 16x2 Character LCD + Keypad for Raspberry Pi =>
It should work. All you need to do is connect 5V (pin 2), gnd, (pin 6) SDA (pin 3) and SCL (pin 5).
The R Pi pinout is here:
http://elinux.org/RPi_Low-level_periphe ... .28GPIO.29
The picture is for a 26-pin header, but the pins are the same on the 40-pin Pi's
- Gerlin
- Gerlin
Ok Rick,
Its works, thanks a lot !
- Fennec42
I have now assembled and tested two of these kits.
They both will when pressing the up and down buttons go to a black lcd. Once another key other than the up or down is pushed it will function as per the install page.
I was wondering if when the the buttons were moved if the o,o,1 and 0,1,0 has changed.
I am not sure which combinations to use to test this.
Do you have monochrome LCDs or RGB LCDs? What's the Adafruit product ID of the plates you bought?
Not sure what you're referring to?Fennec42 wrote:I was wondering if when the the buttons were moved if the o,o,1 and 0,1,0 has changed.
