Adafruit RA8875 and external fonts help
by PlastiBots on Sat May 21, 2016 8:00 am
I've got an Adafruit RA8875 hooked up to their 5" LCD and driving it with a Huzzah ESP8266. I am tying to the the external font examples documented here, but they don't work. I keep getting the default font. Any suggestions?
//for RA8875 LCD
#include <Adafruit_GFX.h>    // Core graphics library
#include "Adafruit_RA8875.h"
#include <SPI.h>
#include <Wire.h>
#include <SD.h>
#include <Fonts/FreeSansBold24pt7b.h>  //these are located in the Adafruit GFX library
#define RA8875_INT 0  //TX pin on the Huzzah
#define RA8875_CS 15  //pin 15
#define RA8875_RESET 2  //pin 2
//// end for RA8875 LCD
//TFT library
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
void setup()
  Serial.begin(115200);
   if (!SD.begin(sd_cs))
    Serial.println("SD initialization failed!");
    return;
  Serial.println("SD initialization done.");
  Serial.println("RA8875 start");
  /* Initialise the display using 'RA8875_480x272' or 'RA8875_800x480' */
  if (!tft.begin(RA8875_800x480)) {
    Serial.println("RA8875 Not Found!");
    while (1);
  Serial.println("Found RA8875");
  //start the TFT
  tft.displayOn(true);
  tft.GPIOX(true);      // Enable TFT - display enable tied to GPIOX
  tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
  tft.PWM1out(255);
  yield();
  doTextSample();
void loop()
//nothing
void doTextSample()
  tft.graphicsMode();                 // go back to graphics mode
  tft.fillScreen(RA8875_BLACK);
  /* Switch to text mode */
  tft.textMode();
  tft.setFont(&FreeSansBold24pt7b);
  tft.textSetCursor(10, 10);
  /* Render some text! */
  char string[15] = "Hello, World! ";
  tft.textTransparent(RA8875_WHITE);
  tft.textWrite(string);
  tft.textColor(RA8875_WHITE, RA8875_RED);
  //tft.textTransparent(RA8875_CYAN);
  //tft.textTransparent(RA8875_GREEN);
  tft.textColor(RA8875_YELLOW, RA8875_CYAN);
  tft.textColor(RA8875_BLACK, RA8875_MAGENTA);
  /* Change the cursor location and color ... */
  tft.textSetCursor(100, 100);
  /* If necessary, enlarge the font */
  tft.textEnlarge(1);
  /* ... and render some more text! */
  //tft.setFont(&FreeSansBold24pt7b);
  //tft.setFont(&FreeSerifItalic24pt7b);
  tft.textEnlarge(3);
  tft.textSetCursor(100, 300);
  //tft.drawChar(300,300, 'A', RA8875_CYAN, RA8875_BLACK, 1);
  //drawChar(int16_t x, int16_t y, unsigned char c, uint16_t color, uint16_t bg, uint8_t size)
  //tft.graphicsMode();
  //tft.fillScreen(RA8875_BLACK);
  //myDelay(100);   //need these to reset the watchdog so it does not rst the processor.  every 3 seconds.
  //bmpDraw("00.bmp", 0, 0);
  //bmpDraw("01.bmp", 101, 0);
  //bmpDraw("02.bmp", 202, 0);
  //bmpDraw("03.bmp", 303, 0);
  //bmpDraw("09.bmp", 404, 0);
  //bmpDraw("12.bmp", 505, 0);
  //bmpDraw("13.bmp", 606, 0);
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster.  20 pixels seems a
// good balance.
#define BUFFPIXEL 80   //original was 20 px increased due to larger RAM on ESP
void bmpDraw(char *filename, int x, int y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
  uint16_t lcdbuffer[BUFFPIXEL];  // pixel out buffer (16-bit per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  uint8_t  lcdidx = 0;
  boolean  first = true;
  if((x >= tft.width()) || (y >= tft.height())) return;
  //Serial.println();
  //Serial.print(F("Loading image '"));
  //Serial.print(filename);
  //Serial.println('\'');
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {
    //Serial.println(F("File not found"));
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    //Serial.println(F("File size: "));
    //Serial.println(read32(bmpFile));
    read32(bmpFile);
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    //Serial.print(F("Image Offset: "));
    //Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    //Serial.print(F("Header size: "));
    read32(bmpFile);
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      //Serial.print(F("Bit Depth: "));
      //Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        //Serial.print(F("Image size: "));
        //Serial.print(bmpWidth);
        //Serial.print('x');
        //Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
          pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each column...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              // Push LCD buffer to the display first
              if(lcdidx > 0) {
                tft.drawPixel(col+x, row+y, lcdbuffer[lcdidx]);
                lcdidx = 0;
                first  = false;
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // Convert pixel from BMP to TFT format
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            lcdbuffer[lcdidx] = color565(r,g,b);
            yield(); //added due to WTD reset issue with ESP.
          } // end pixel
        } // end scanline
        // Write any remaining data to LCD
        if(lcdidx > 0) {
        //Serial.print(F("Loaded in "));
        //Serial.print(millis() - startTime);
        //Serial.println(" ms");
      } // end goodBmp
  bmpFile.close();
  if(!goodBmp) Serial.println(F("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
uint16_t color565(uint8_t r, uint8_t g, uint8_t b) {
  return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
byte decToBcd(byte val){
  // Convert normal decimal numbers to binary coded decimal
  return ( (val/10*16) + (val%10) );
PlastiBots
Re: Adafruit RA8875 and external fonts help
by ecdowney on Sun Jul 10, 2016 12:26 pm
I got this to work as follows:
1. Edit Adafruit_RA8875.h and comment out the virtual size_t write() function
2. Use tft.graphicsMode() for the GFX functions:
tft.graphicsMode();
tft.setCursor(100,300);
tft.setTextSize(1);
tft.print(string);
ecdowney
by rmetzner49 on Sun Apr 16, 2017 11:05 pm
Great tips, thank you. I was struggling with this as well.
You might mention the tft.setTextSize(2); still seems to work though it's fairly fuzzy around the edges.
I might bite the bullet and roll a 48pt font or find one already done. Now if I could just get the blasted GSL1680 touch controller to work ... Doesn't help I'm doing all this with the ESP32, for which many things aren't fully debugged yet. I have my display working SPI mode but I can't upload a sketch unless I remove the "SS" pin from the display to the ESP32.
Bob M.
rmetzner49
by rmetzner49 on Tue Apr 18, 2017 3:44 pm
So on an issue related to the SPI mode of the RA8875 Board, how do we determine if this board as "Transaction Support"?
Is the Arduino SPI Library treating this properly? What I believe SHOULD happen as I view the code is; the SPI Bus is supposed to be initialized as an object that has mosi, miso, clk and ss. I see where the code "attaches" and "detaches" the first three, but I don't see 'ss' being handled.
My symptom is; all works fine on the display, but I MUST leave "ss" disconnected while uploading a sketch. This is because the ESP32-Thing has an SPI flash chip. What I think happens is, "ss" must interfere by enabling MISO thereby clobbering the upload process.
Any suggestions would be appreciated.
rmetzner49
by cmpxchg8b on Fri Apr 21, 2017 3:02 am
rmetzner49 wrote:So on an issue related to the SPI mode of the RA8875 Board, how do we determine if this board as "Transaction Support"?
If you mean SPI transactions, they are purely a software concept. So the question is not whether the board supports them, but whether the Adafruit RA8875 library uses them. The library does use them.
Not sure about the SS pin, but the RA8875 chip has a hardware bug where it continues to drive the MISO pin all the time, which makes it a bad citizen that will have problems sharing an SPI bus with other devices. If you're having trouble talking to other SPI devices when your RA8875 is connected, you might look into that as a possible cause.
cmpxchg8b
by rmetzner49 on Fri Apr 21, 2017 12:35 pm
Thanks, I did read that little quirk about the RA8875 and am awaiting a 74AUP1G2 to arrive and scab into my board. The weird thing is, I made the problem go away by using D0 instead of D2 for the /CS. That doesn't make any sense but it lets me upload for now. WRT the MISO line, I plan to scab the 74AUP1G2 in the series path back to the ESP32. I don't want to chew up an output to drive the /OE pin on it, so I'll try to see if just having it run from the RA8875 - /CS, so it's only ON when accessing the dispay.
I checked the ESP32-THING artwork and there is no other connection to D2, so unless I want to pick apart the BIOS to see if something else is tweaking D2, this will have to do.
Regards,
Bob M.
rmetzner49
by jjuni on Mon Jul 17, 2017 3:46 pm
I, too, am trying to drive an RA8875 from a HUZZAH32 ESP32 Feather. I need help understanding the above discussion.
1) I see the SCK, MISO and MOSI lines needed to drive the RA8875 by SPI, but I don't see the CS. The previous post mentions using D0 or D2 for this, but I see no such pends on the ESP32 Feather. What should I use?
2) The RA8875 also expects a RST line. What do I use for this?
3) To use the touchscreen reader of the RA8875, I need to connect to its INT line. Where should I do this on the Feather?
4) Since I am not using SPI for anything other than the RA8875, do I have to worry about it's problems sharing the MISO line?
5) Do I have to modify any libraries or other code to do the above?
Sorry for so many questions.
Thanks in advance,
Jack
jjuni
by cmpxchg8b on Mon Jul 17, 2017 4:23 pm
You should be able to use any free GPIO pins for these three. Just make sure it matches your source code. The example programs have #define lines at the top where you tell it which pins you are using for these 3 functions:
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
Also, you'll probably have to set the INT pin to INPUT mode yourself in the setup() function:
pinMode(RA8875_INT, INPUT);
Note that the example programs don't seem to actually use the INT pin with an interrupt. They just poll it.
If the MISO line really isn't shared with other SPI devices you might use, then you don't have to worry about it. But that includes devices that are built onto the Feather board.
For example, the ESP32 Feather has a 4MB SPI flash. Does it use the same MISO line? I'm not sure...
cmpxchg8b
by rmetzner49 on Mon Jul 17, 2017 4:39 pm
Jack:
1 & 2) The hardware SPI Module talking to the RA8875 I believe works only on CS=5. At least that's what I determined after days of mucking around with it. If you sniff through RA8875.CPP it talks about "VSPI", which is the one the display wants to camp on.
2) You don't need the Reset Pin but the Library is expecting it to be assigned, so pick any unused pin.
3) The INT use on the Touchscreen is for the RA8875. Mine works just fine. I think the RA8875 gets an interrupt and then sends it out the SPI line.
4 & 5) I put a copy of the RA8875.CPP and H files into my sketch folder and used #include "RA8875.h". I did this mostly because I didn't think the SPI Speed was being properly set since I had NO idea how the ESP32 identifies itself, so I commented out all that conditional garbage and set my SPI Speed at 3MHz. I tried it all the way up to 8Mhz, but it won't start from a reset anything above 4Mhz. I haven't dug into why. You shouldn't have to isolate the MISO line if the display is the only device on that pin. Unfortunately I had a DS3234 Clock Chip on it and never got it to work, so I've scrapped that idea in favor of using I2C with a DS3232 instead. Hope that helps. Bob M.
rmetzner49
by rmetzner49 on Mon Jul 17, 2017 4:55 pm
Once you get your TS working, here is a function I rolled to decode the buttons. the "block[row][2] etc. are indexes to the array of buttons, because you have to have that to decode them. There is probably a more elegant way to do this but between button bounce and grabbing multiple values, this is what I ended with. Notice I immediately make copies of the coordinates, set a flag and then MAP it to screen locations. The MATH is simply the MAP macro exploded. I should point out until I called the mapped copies "static uint32_t" I got garbage. Easy to see why when you look at the equation. The multiply makes an overflow.
/ts ============================ Touch Screen Button Decoder ===============================
// Enter with: screen#         returns: Button #
uint8_t GetButton(uint8_t scrn)  {
  uint8_t row,b,e;
  volatile uint8_t c;
  uint16_t tX;//  location of touch coordinates
  uint16_t tY;
  uint16_t cx;//  copies
  uint16_t cy;
  static int32_t xx; //mapped copies
  static int32_t yy;
c=0; xx=0; yy=0;
// *** check the buttons
   if (tft.touched())
     {                                          // check button
     tft.touchRead(&tX, &tY);                   // address of globals
     cx=tX; cy=tY; c=1;                         // make a copy to shorten up TOUCHED
     }// end if touched
 if(c)
    xx=((cx - TS_MINX) * 800L) / (TS_MAXX - TS_MINX);
    yy=((cy - TS_MINY) * 480L) / (TS_MAXY - TS_MINY);
    row=0;  // Set beginning row
    TS_Debounce=TS_Debnce.Time(300);
    if(TS_Debounce){
      do{       //    x-start                           x  +  width
           if (((xx > bloc[row][2]) && (xx < bloc[row][2] + bloc[row][4]))      // If screen coordiates match
           &&  ((yy > bloc[row][3]) && (yy < bloc[row][3] + bloc[row][5]))
           &&   (scrn == bloc[row][0]))                                        // AND the button is on the right screen
       return (row);
       row++;             // no button can be larger than the array!
       } while  (row<=27);// end while
}//------------------ end TB decoder -----------------------------------------
rmetzner49
by jjuni on Tue Jul 18, 2017 12:01 pm
Success!!! I now have the HUZZAH32 Feather driving the RA7785 board to a 7" TFT. Both display and touchscreen are working.
I set RA8875_CS to GPIO #4, RA8875_RESET to GPIO# 36 and RA8875_INT to GPIO #39. Set the INT pin to INPUT. No evidence of interference with flash so far, although I am only using it to hold the program.
rmetzner49, I don't see GPIO #5 broken out on the ESP32 Feather, so used #4 which seems to work fine. I've used the stock RA8875.cpp and .h files which seem to be working okay without modification so far.
Looking at the RA8875 data sheet, it seems it is capable of being driven by I2C as well as SPI. Too bad the I2C is not available on the breakout board. Perhaps, something for next version, Adafruit?
Thanks to all, especially cmpxchg8b and rmetzner49.
jjuni
by rmetzner49 on Tue Jul 18, 2017 2:44 pm
Jack;
for decoding your touch screen and making elements, take a LONG look at Adafruit's GFX library and see if you can use the GFX buttons. I didn't use them, opting instead to just create an array of locations but the OBJECTS might make it cleaner. I started with an earlier version of GFX that didn't have the buttons and I wasn't wanting to start over.
Glad you got it to work, possibly because the Feather's I/O pin and the Thing's are somewhat different. As far as the Flash, you will notice it's connected to HSPI and your display is on VSPI. I also hope you used the ESP32-hal-spi.h from Espressif.
Not sure why you'd want to use I2C instead of SPI, from my understanding it's less robust and slower. In my case, I'm OK with using the Clock chip on I2C because you only need to pass data once every so often.
Bob M.
rmetzner49
by jjuni on Wed Jul 26, 2017 3:18 pm
I have already written a little GUI library to handle drawing, highlighting and reading buttons and other controls. The code is not pretty, but it meets the needs of the project. Last I looked (almost a year ago) the GFX library did not have support for much other than graphics primitives. If it now supports controls, that's a huge improvement!
I'm just using the SPI.h library included in the Espressif ESP32 package, rather than the ESP32-hal-spi.h library. Although the ESP32-hal-spi.h seems to provide more low-level functionality, the "plain" SPI.h library seems to be working. Any reason I should switch?
Your comment made me aware that there are a large number of ESP32-hal-xxx libraries in the core directory of the ESP directory. Why does Espressif provide two different sets of libraries? How does one know which to use?
Since the RA8875 does not properly release one of the SPI lines, it is not possible to use multiple devices on the same SPI bus. I mentioned I2C as a potential alternate way to free up the SPI if one needed it for something else and didn't want to mess with a seperate tri-state chip. I have no specific use scenario in mind.
Thanks for all the help, metzner49!
-- Jack
jjuni
by jjuni on Wed Jul 26, 2017 3:28 pm
Just found the button routines in the GFX library. If they were there before, I missed them, probably because they weren't in the documentation PDF I had. They looks really useful. Thank you, Adafruit!
jjuni
by jjuni on Tue Aug 22, 2017 11:26 am
I see that the button routines are still not mentioned on the PDF documentation https://learn.adafruit.com/adafruit-gfx%20...%20y/overview. Neither are GFX canvases. It would really be helpful if these were at least mentioned so users knew they were there. Examples, of course, would be great, too.
jjuni
