Micro:bit servo control
Ailstyn
Post by Ailstyn »
Hello, I trying to use the towerpro micro servos from adafruit (https://www.adafruit.com/product/169) with the BBC Micro:bit. So far, the most I've gotten out of it is a soft clicking noise and zero movement. I've tried using an external power source for the servo, but that did even less (eg: nothing). I can't see any reason they shouldn't be compatible, but I am stuck.
adafruit_support_carter
Re: Micro:bit servo control
This guide uses a servo and might be useful:
https://learn.adafruit.com/micro-bit-ra ... troduction
See the info there helps.
If not, post a photo of your setup showing how you've connected the servo to the micro:bit.
Ailstyn
Post by Ailstyn »
It's a little hard to see in the photo, but it is hooked up brown-GND, orange-3V, yellow-0.
Ailstyn
Post by Ailstyn »
Sorry, should have mentioned: yes, I followed the instructions and that setup is the same as far as I can see. It produces the quiet clicking noise I mentioned, but no movement.
That seems OK. What does your program look like?
Ailstyn
Post by Ailstyn »
Pressing either button makes the LEDs display the correct pattern, and the nonstop clicking.
jerryn
Post by jerryn »
Just an observation. Is is possible that your white alligator clip is also contacting the pin next to P0 (P4).
Good luck!
How are you powering the micro:bit? Can you power it via battery?
Ailstyn
Post by Ailstyn »
When I power it from the 2xAA pack for the micro:bit it does the nonstop clicking, if I power the board through the USB cable it clicks once, and then I think it resets because the screen goes black, shows the "on start" screen, and the computer re-mounts it.
I'm getting the same behavior. Not sure what's causing this but probably related to the servo drawing power.
Batteries are working OK for me. Are yours fresh? And are they alkaline or rechargeable? (I'm using alkaline)
Ailstyn
Post by Ailstyn »
I'm using the batteries the micro:bit shipped with, which are actually triple-A not double, and do not say what kind they are. The battery pack itself says "only carbon-zinc or alkaline", so I assume it's one of those. When the board is powered I put a voltmeter to it and it outputs a constant 2.8V. I'll try picking up some fresh alkaline batteries tonight and see if they work better.
Hmmm. Same here. And I'm also using that exact same servo. Go over your wiring to make sure it's all solid. I'm using these:
https://www.adafruit.com/product/3255
straight into the servo connector, so it's a little cleaner.
Ailstyn
Post by Ailstyn »
I bought some fresh AAA's and it's working for me now, which is a nice neat solution. I did try powering with external batteries but my wiring must have been bunk, I'll have to try it again sometime just so I know. For now the crisis is averted, thanks for the help!
Return to “For Educators”
