Powerboost
Powerboost
by ipadeflteacher on Wed Sep 26, 2018 9:41 am
I am helping a student build a Pi GRRL 2 and after soldering everything up the PowerBoost gets super hot. We desoldered everything but it still gets super hot on battery power (2500mah battery from the kit) and on USB. Only the orange charging light comes on with the battery plugged in or the usb.
I've searched all through the forums and I guess I am not the only one who has had this problem. I don't have a voltage meter.
What should I do. Unfortunately, we were hoping to have his project finished for Maker Faire this weekend but I guess that's impossible.
Please advise,
Richard
ipadeflteacher
Re: Powerboost
by adafruit_support_carter on Thu Sep 27, 2018 12:30 pm
Sounds like something may have gotten shorted. Did you try testing it out before soldering it into the project?
Re: Powerboost
by ipadeflteacher on Thu Sep 27, 2018 11:03 pm
We did. It got pretty hot then too. I read online that the PowerBoost usually gets pretty hot so I didn't think it was a problem. However, now it gets super hot that it might melt the PLA case.
Richard
ipadeflteacher
Re: Powerboost
by adafruit_support_carter on Fri Sep 28, 2018 3:58 pm
Was it ever used without the battery attached? Like the Pi was wired to the output of the Powerboost and then a USB cable was plugged into the Powerboost with no battery attached.
Re: Powerboost
by ipadeflteacher on Mon Oct 01, 2018 10:23 pm
Never got a chance to even try plugging in the USB cable when it was all soldered together. After it got super hot on the battery we decided to desolder everything to figure out what causing the problem. That's when we discovered that the PowerBoost might be the problem.
ipadeflteacher
Re: Powerboost
by adafruit_support_carter on Tue Oct 02, 2018 11:13 am
Can you post a photo of board showing both sides.
Re: Powerboost
by ipadeflteacher on Fri Oct 05, 2018 11:48 pm
Sure! Here is a photo of the back!
ipadeflteacher
Re: Powerboost
by adafruit_support_carter on Tue Oct 09, 2018 1:45 pm
Just noticed this in your first photo. Looks like there is a component missing from the top of the board. Do you know if that could have somehow been knocked off during the build?
Re: Powerboost
by ipadeflteacher on Wed Oct 10, 2018 11:14 pm
That's totally possible! I totally missed that. I guess I will have to order another PowerBoost! Thanks for the help!!
ipadeflteacher
Re: Powerboost
by adafruit_support_carter on Thu Oct 11, 2018 11:08 am
Sorry that happened. Be sure to check the new one before you put it in the project and make sure it's functional. That way you'll know it arrived OK and any subsequent problems will be a result of some aspect of the build. Just a simple sanity check that will help with any trouble shooting, esp. when doing a more complex build like a Pi GRRL. Good luck and hope you get it working!
