Rasperry pi help
Rasperry pi help
by ridanleffell on Sun Jan 12, 2020 10:56 pm
Hello all,
We have purchased 5 raspberry pis for our engineering program at our school.
Four of them seem to have stopped working.
After checking the sticky post I have found that all those PIs don't show 3v3 when tested.
It says they are not user repairable (In the sticky post).
So how do I fix them? or where do I send them to be fixed?
Thanks,
ridan
ridanleffell
Re: Rasperry pi help
by adafruit_support_carter on Mon Jan 13, 2020 6:35 pm
Where the Pi's used by students? In particular, did anything touch the GPIO headers? Those pins expose very sensitive parts of the Pi. We try to cover that aspect here:
https://learn.adafruit.com/raspberry-pi ... g/overview
by ridanleffell on Mon Jan 13, 2020 10:48 pm
adafruit_support_carter wrote:Where the Pi's used by students? In particular, did anything touch the GPIO headers? Those pins expose very sensitive parts of the Pi. We try to cover that aspect here:
Thanks for the reply.
Two of them were used by students, and two didn't. We explained the importance of caution with the GPIOs.
Is there a way to fix the pi?
ridanleffell
by adafruit_support_carter on Tue Jan 14, 2020 2:40 pm
Unfortunately, not easily. And the cost would be more than just a replacement board. Damaging the voltage regulator via accidental shorting of the GPIO pins is a common issue.
If you are having issues with one of the un-used boards, that is something we can replace. But for the others, once anything touches the GPIO headers, it is essentially a warranty voiding event.
by ridanleffell on Tue Jan 14, 2020 2:48 pm
adafruit_support_carter wrote:Unfortunately, not easily. And the cost would be more than just a replacement board. Damaging the voltage regulator via accidental shorting of the GPIO pins is a common issue.
Thanks.
So how can we fix the two unused boards?
ridanleffell
by adafruit_support_carter on Tue Jan 14, 2020 2:52 pm
Let's troubleshoot those a little further.
First, just to be clear, nothing has been attached to the GPIO headers on these boards? They are essentially straight from the box.
And the current condition is that you are not seeing 3.3V on the GPIO header when the board is powered? If so, how are you making that measurement.
by ridanleffell on Tue Jan 14, 2020 2:59 pm
Yes.
Out of the box.
I check with DMM the voltage between the 3v3 pin and the housing of the HDMI port, as explained in the sticky post.
ridanleffell
by adafruit_support_carter on Tue Jan 14, 2020 3:45 pm
As a sanity check for the DMM measurement, try measuring the voltage on one of the 5V pins. Here's another good reference for the pinouts:
https://pinout.xyz/#
by emmabhatti on Tue Jan 28, 2020 5:40 am
Raspberry pis can only be send back from where you have purchased, like from store or shop that you have purchased so you need to take back to them not any other 3rd person or even not official product dealers are responsible for this. The one and the only that can help you with this is from the person whom you have purchased and handed the cash.
You have no any other option as I have experienced this already.
I hope it help you out
thanks.
emmabhatti
