No PWM on Feather Huzzah?
by Kokodoko on Thu Feb 13, 2020 11:20 am
I just bought a couple of Feather Huzzah boards for my institution. We want to teach students about connecting to the internet with a microcontroller.
I got the internet connection working, but then I discovered I can't use PWM on the Huzzah board? I tried the following code, but the numbers in analogWrite() are ignored. It seems PWM is not available?
I studied the diagrams of the board but there is no mention of PWM. If the "squiggly lines" mean PWM, then all the GPIO pins should support PWM?
My code:
  pinMode(15, OUTPUT);
  for (int brightness = 0; brightness < 255; brightness++) {
    analogWrite(15, brightness);
    delay(1);
Erik.
Kokodoko
Re: No PWM on Feather Huzzah?
by kcl1s on Thu Feb 13, 2020 11:39 am
All the pins with the sine wave line are PWM capable in this pinout drawing https://learn.adafruit.com/assets/46249 The only difference is pwm is 0 - 1024 compared to 0 - 255 on the Uno. You can see it in use in this guide https://learn.adafruit.com/adafruit-io-basics-analog-output?view=all
Fellow hobbyist
Keith
kcl1s
by Kokodoko on Fri Feb 14, 2020 7:36 am
Thanks! I found the documentation quite sparse and hard to find, but this forum helps !
Kokodoko
