Due to high demand, expect some shipping delays at this time - orders may not ship for up to 2-3 business days.
Using a Trinket MO for Neopixel Light Box Project
by zackboston on Wed Jan 19, 2022 6:32 am
I am working with a class of Juniors at Boston's Madison Park Technical Vocational High School doing a Light box project with an etched acrylic panel mounted on a lasercut box that is lit by neopixels. Since all the youth have Chromebooks, I have used CodeBender to do the coding.
I have Trinket MOs for all the youth --- I have always used regular trinkets in the past. I also have a Adafruit neopixel reel and rocker switches. I have some questions.
Will the Trinket MO work using the regular trinket board 8 MHz settings on Codebender or do I need to add a library?
Can I still connect the neopixel strips (no more than 8 neopixels for the largest project) to any numbered pin?
Since it does not have an ATTiny, how does that change the set up code and settings in Arduino?
Thanks for any help or links you can give me!
Susan at the Mel King Fab Lab
zackboston
Re: Using a Trinket MO for Neopixel Light Box Project
by adafruit_support_carter on Wed Jan 19, 2022 2:51 pm
I don't think CodeBender supports the Trinket M0. All the supported boards:
https://codebender.cc/boards
are AVR based (a specific microcontroller type). The Trinket M0 is ARM based, which is a very different microcontroller.
It is possible to drive NeoPixels with a Trinket M0. But you'll need to use something other than CodeBender. Check out the main guide for the Trinket M0 for some info on options:
https://learn.adafruit.com/adafruit-tri ... o/overview
