Circuit Playground Classics---dying in droves
Re: Circuit Playground Classics---dying in droves
by adafruit_support_carter on Mon May 16, 2022 2:48 pm
Yah. Really weird.
Try this and see if it helps:
https://learn.adafruit.com/introducing- ... aq-2921702
by shop4mondon on Mon May 16, 2022 4:32 pm
We have tried everything we could find on this website
No Luck
Is it possible that all of them are defective...or they just broke, wore out?
shop4mondon
by adafruit_support_carter on Mon May 16, 2022 4:46 pm
Very unlikely they are all defective.
Just to be sure - at this point, you have a Circuit Playground that is known to *never* have been used by students? If so, please post a photo of both sides of that Circuit Playground. We'll look for any obvious hardware issues.
by shop4mondon on Tue May 17, 2022 12:47 pm
Here ya go
shop4mondon
by adafruit_support_carter on Tue May 17, 2022 12:52 pm
Thanks. Nothing obvious.
What happens if you plug in that CP and double press the reset button? What does the little red #13 LED next to the USB connector do?
by shop4mondon on Tue May 17, 2022 12:57 pm
We have tried reseting....and double clicking the reset button. The red light flashes, but our sketches still don't upload
Are we missing a step?
Can you tell me something we can't find on the website
shop4mondon
by adafruit_support_carter on Tue May 17, 2022 1:11 pm
The red flashing is good - that means the bootloader is still there and running as expected. So the board is not dead.
It seems like the recovery process here should work:
but it did not for some reason.
In the Arduino IDE, are you selecting the Circuit Playground from the Adafruit board support?
Tools > Board > Adafruit Boards > Adafruit Circuit Playground Classic
Or from the Arduino board support?
Tools > Board > Arduino AVR Boards > Adafruit Circuit Playground
by shop4mondon on Tue May 17, 2022 1:25 pm
Here's the error code I just received
Arduino: 1.8.19 (Mac OS X), Board: "Adafruit Circuit Playground"
Sketch uses 3868 bytes (13%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port /dev/cu.usbmodem142101
PORTS {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem142101, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem142101, } / {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, } => {}
PORTS {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, } / {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, } => {}
PORTS {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, } / {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem142101, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem142101, } => {/dev/cu.usbmodem142101, /dev/tty.usbmodem142101, }
Found upload port: /dev/cu.usbmodem142101
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/cu.usbmodem142101 -b57600 -D -Uflash:w:/var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_729552/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/don.carter/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem142101
Using Programmer : avr109
Overriding Baud Rate : 57600
avrdude: ser_drain(): read error: Device not configured
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: ser_send(): write error: Device not configured
avrdude: ser_recv(): read error: Device not configured
avrdude: butterfly_recv(): programmer is not responding
the selected serial port avrdude: butterfly_recv(): programmer is not responding
does not exist or your board is not connected
Found programmer: Id = "?��"; type =
Software Version = .; Hardware Version = 0.�
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude: ser_close(): can't reset attributes for device: Device not configured
avrdude done. Thank you.
shop4mondon
by adafruit_support_carter on Tue May 17, 2022 1:38 pm
by shop4mondon on Tue May 17, 2022 2:05 pm
Here's a screenshot
Screen Shot 2022-05-17 at 10.55.23 AM.png (291.63 KiB) Viewed 150 times
shop4mondon
by adafruit_support_carter on Tue May 17, 2022 2:20 pm
Thanks. Looks like the Arduino one.
And just to verify the general history - the CP shown in the photo has never been used by students, it used to work and successfully upload sketches, but at some point, for unknown reasons, it suddenly responds with the upload issue shown above? It is also unknown what the last successful sketch upload to the CP was?
No other changes involved. Same sketch. Same USB cable. Same PC.
by shop4mondon on Tue May 17, 2022 2:24 pm
Yep, Yep, and Yep
THANX for all of your dedicated responses.
We work with lots of gadgets and we can usually resolve issues on or own...or with a few suggestions from friendly folks like yourself.
But, we seem to be stumped
shop4mondon
by adafruit_support_carter on Tue May 17, 2022 2:28 pm
At this point, do you have any CP's that still accept a new sketch upload?
by shop4mondon on Tue May 17, 2022 2:37 pm
We have two boards that are embedded in projects....and they are currently functioning.
Frankly, I'm afraid to try to upload any other sketches or experiment with them. We have an event coming up where we need them to work.
All 6 of the available boards have quit.
shop4mondon
by adafruit2 on Tue May 17, 2022 3:08 pm
@shop do you know how to use CMD or Powershell in windows or Terminal in mac? the boards aren't bricked but we're not 100% sure what happening with your setup and we want to remove a level of complexity by skipping the IDE
adafruit2
Site Admin
cron
