Howdy
I can use the terminal....we have Macs, mostly
Are you going to send me some instructions?
Circuit Playground Classics---dying in droves
- shop4mondon
- adafruit2
Re: Circuit Playground Classics---dying in droves
ok sure on the Mac try to upload and then use the
block above to paste the exact output from the upload failure
- westfw
Are you sure? Operating systems can get updates that are not very visible to the end users, especially in a "managed" environment like many schools and other educational setting.We have not changed anything.
Have you tried a misbehaving board on an "outside" PC?
- shop4mondon
We have tried on MacOs, Windows, on the school network and off
- shop4mondon
adafruit2 wrote:ok sure on the Mac try to upload and then use theCode: Select all
block above to paste the exact output from the upload failure[/quote] Howdy I can't seem to find the code block you mention
- adafruit2
here it is
- Attachments
- Screenshot_2.png (13.77 KiB) Viewed 2182 times
- freddyboomboom
I don't use Arduino so take what I'm saying with that in mind.
Carter says the class looks like they're using the Arduino board definition for the Circuit Playground.
The picture says it's a Circuit Playground Classic.
Is there a reason to NOT use the Adafruit board definition for the Circuit Playground Classic board?
Or are they effectively identical as far as the different board definition files in the Arduino IDE?
- shop4mondon
adafruit2 wrote:here it is
I apologize, but I don't understand what you want me to try.
You mentioned that you want me to bi-pass the Arduino IDE and use the terminal to communicate with the CP...right?
I do not know what commands to use to do that.
I only see the CODE button in the Post box...not the box I read your responses
- adafruit2
hi please can everyone except mondon stop posting in this thread for now? we are trying to help them and its harder when 3 extra folks are posting too :)
mondon, on the Mac try to upload and then use the
block above to paste the exact output from the upload failure. thats what we are asking you to do now.
- shop4mondon
Howdy
I'm Don ;-)
I thought that you wanted me to use the terminal to communicate with the CP in order to bypass the Arduino IDE, so I needed the commands....
....but, I have added the error message
Let me know what else I can do to help
THANX
I'm Don ;-)
THANX
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/don.carter/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/don.carter/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/don.carter/Documents/Arduino/libraries -fqbn=arduino:avr:circuitplay32u4cat -ide-version=10819 -build-path /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804 -warnings=none -build-cache /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_cache_589180 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avr-gcc.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/don.carter/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/don.carter/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/don.carter/Documents/Arduino/libraries -fqbn=arduino:avr:circuitplay32u4cat -ide-version=10819 -build-path /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804 -warnings=none -build-cache /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_cache_589180 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avr-gcc.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
Using board 'circuitplay32u4cat' from platform in folder: /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3
Using core 'arduino' from platform in folder: /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3
Detecting libraries used...
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/sketch/Blink.ino.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/sketch/Blink.ino.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/wiring_pulse.S -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_pulse.S.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/wiring.c -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/WInterrupts.c -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/WInterrupts.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/hooks.c -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/hooks.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/wiring_analog.c -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_analog.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/wiring_digital.c -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_digital.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/wiring_pulse.c -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_pulse.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/wiring_shift.c -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_shift.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/CDC.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/CDC.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/HardwareSerial1.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial1.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/HardwareSerial.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/HardwareSerial0.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial0.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/HardwareSerial2.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial2.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/HardwareSerial3.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial3.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/IPAddress.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/IPAddress.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/PluggableUSB.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/PluggableUSB.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/Print.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/Print.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/Stream.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/Stream.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/Tone.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/Tone.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/USBCore.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/USBCore.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/WMath.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/WMath.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/WString.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/WString.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/abi.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/abi.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/main.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/main.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/new.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/new.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_pulse.S.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/WInterrupts.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/hooks.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_analog.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_digital.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_pulse.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/wiring_shift.c.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/CDC.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial0.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial1.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial2.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/HardwareSerial3.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/IPAddress.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/PluggableUSB.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/Print.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/Stream.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/Tone.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/USBCore.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/WMath.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/WString.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/abi.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/main.cpp.o
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/new.cpp.o
Archiving built core (caching) in: /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_cache_589180/core/core_arduino_avr_circuitplay32u4cat_420cd4175fc47b2c53baf576a0b363b4.a
Linking everything together...
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/Blink.ino.elf /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/sketch/Blink.ino.cpp.o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/core/core.a -L/var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804 -lm
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/Blink.ino.elf /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/Blink.ino.eep
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/Blink.ino.elf /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/Blink.ino.hex
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_639804/Blink.ino.elf
Sketch uses 3868 bytes (13%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes of dynamic memory.
PORTS {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem141101, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem141101, } / {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem141101, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem141101, } => {}
Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
- adafruit2
ok try again - this time during upload when its printing that long red list of text, double click the reset button to get the pulsing red LED that means its bootloading, then paste the code box output again!
- shop4mondon
HERE YA GO
Arduino: 1.8.19 (Mac OS X), Board: "Adafruit Circuit Playground"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/don.carter/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/don.carter/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/don.carter/Documents/Arduino/libraries -fqbn=arduino:avr:circuitplay32u4cat -vid-pid=239A_8011 -ide-version=10819 -build-path /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542 -warnings=none -build-cache /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_cache_780023 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avrdude.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/don.carter/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/don.carter/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/don.carter/Documents/Arduino/libraries -fqbn=arduino:avr:circuitplay32u4cat -vid-pid=239A_8011 -ide-version=10819 -build-path /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542 -warnings=none -build-cache /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_cache_780023 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avrdude.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/sketch/Blink.ino.cpp -o /dev/null
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/sketch/Blink.ino.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/Users/don.carter/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/variants/circuitplay32u4 /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/sketch/Blink.ino.cpp -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/sketch/Blink.ino.cpp.o
Compiling core...
Using precompiled core: /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_cache_780023/core/core_arduino_avr_circuitplay32u4cat_420cd4175fc47b2c53baf576a0b363b4.a
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/Blink.ino.elf /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/sketch/Blink.ino.cpp.o /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/../arduino_cache_780023/core/core_arduino_avr_circuitplay32u4cat_420cd4175fc47b2c53baf576a0b363b4.a -L/var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542 -lm
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/Blink.ino.elf /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/Blink.ino.eep
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/Blink.ino.elf /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/Blink.ino.hex
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/Blink.ino.elf
Forcing reset using 1200bps open/close on port /dev/cu.usbmodem141101
PORTS {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem141101, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem141101, } / {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, } => {}
PORTS {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, } / {/dev/cu.BLTH, /dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem141101, /dev/tty.BLTH, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem141101, } => {/dev/cu.usbmodem141101, /dev/tty.usbmodem141101, }
Found upload port: /dev/cu.usbmodem141101
/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/cu.usbmodem141101 -b57600 -D -Uflash:w:/var/folders/r0/s0z6_qp14vz_60z3tbj59xrd0343ws/T/arduino_build_201542/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/don.carter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/don.carter/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem141101
Using Programmer : avr109
Overriding Baud Rate : 57600
avrdude: ser_drain(): read error: Device not configured
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: ser_send(): write error: Device not configured
avrdude: ser_recv(): read error: Device not configured
avrdude: butterfly_recv(): programmer is not responding
the selected serial port avrdude: butterfly_recv(): programmer is not responding
does not exist or your board is not connected
Found programmer: Id = "����"; type =
Software Version = .; Hardware Version = @.L
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude: ser_close(): can't reset attributes for device: Device not configured
avrdude done. Thank you.
Last edited by adafruit_support_carter on Thu May 19, 2022 1:28 pm, edited 1 time in total.
Reason: fixed [code] tags
- adafruit2
ok great, first up, please check your post after its created and edit the post if needed to put it in a 'code' block, it will make it easier to scroll/read these large chunks of text
next up.
quit the IDE
type into your Terminal
but DONT hit return
plug in the CircuitPlayground into the computer, and doubleclick the reset button until the red #13 LED is pulsing. it will only do this for about 4 seconds
WHILE IT IS PULSING hit return
paste the output into a code box here
next up.
quit the IDE
ls /dev/cu.* /dev/tty.*
- shop4mondon
/dev/cu.BLTH /dev/tty.BLTH
/dev/cu.Bluetooth-Incoming-Port /dev/tty.Bluetooth-Incoming-Port
/dev/cu.usbmodem141101 /dev/tty.usbmodem141101
- adafruit2
ok gr8 now wait till its out of the bootloader, so you dont have the pulsing red LED, and do the same thing, whats the output from the terminal?
