Circuit Playground Classics---dying in droves
Re: Circuit Playground Classics---dying in droves
by shop4mondon on Thu May 19, 2022 2:20 pm
/dev/cu.BLTH            /dev/tty.BLTH
/dev/cu.Bluetooth-Incoming-Port      /dev/tty.Bluetooth-Incoming-Port
/dev/cu.usbmodem141101         /dev/tty.usbmodem141101
shop4mondon
by adafruit2 on Sat May 21, 2022 11:33 pm
ok cool, next up do you have homebrew installed on the mac, so you can run 'brew install lsusb'?
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 11:36 am
No, I do not have "Home Brew"...
...But, I can look for it and install it
shop4mondon
by adafruit2 on Tue May 24, 2022 11:39 am
its really useful! its also the easiest way for us to find the VID/PID that will tell us if the bootloader is launching right!
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 12:07 pm
OK
I installed Home Brew
I will need coaching on the next steps
shop4mondon
by adafruit2 on Tue May 24, 2022 1:42 pm
install with
brew install lsusb
https://formulae.brew.sh/formula/lsusb
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 2:16 pm
I have it installed
What's next ?
shop4mondon
by adafruit2 on Tue May 24, 2022 2:37 pm
ok in bootloader mode and plugged into mac, run `lsusb` in terminal
then do the same in non-bootloader mode
paste BOTH outputs and indicate which is which
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 4:43 pm
I got an error message in the Terminal telling me "command not found"
shop4mondon
by adafruit2 on Tue May 24, 2022 5:27 pm
`brew install lsusb` didnt work then
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 5:40 pm
I tried to upload the sketch and ran the code in the terminal. I got the output in screenshot1
Then, I tried to upload again...double clicked the reset button and got the code in screenshot2
Screen Shot 1.png (64.27 KiB) Viewed 442 times
Screen Shot 2.png (15.4 KiB) Viewed 443 times
shop4mondon
by adafruit2 on Tue May 24, 2022 7:08 pm
ok now run lsusb in the windows
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 7:10 pm
I don't know what you mean when you say run it in the windows
shop4mondon
by adafruit2 on Tue May 24, 2022 7:21 pm
the terminal window
type in
lsusb
the program ya just installed
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 7:24 pm
THANX
Here's what I got
Last login: Tue May 24 14:24:37 on ttys000
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
BSH-STF-DCARTE3:~ don.carter$ lsusb
2022-05-24 16:13:43.518 system_profiler[17926:332216] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-05-24 16:13:43.519 system_profiler[17926:332216] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-05-24 16:13:43.520 system_profiler[17926:332216] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-05-24 16:13:43.521 system_profiler[17926:332216] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
Bus 020 Device 001: ID 05ac:100f Apple Inc. USB2.0 Hub
Bus 020 Device 013: ID 046d:c016 Logitech Inc. Optical USB Mouse
Bus 020 Device 002: ID 05ac:1460 Apple Inc. USB-C Digital AV Multiport Adapter  Serial: DLC926700K3G2KQAE
Bus 000 Device 001: ID 05ac:100e Apple Inc. USB3.0 Hub
/usr/local/bin/lsusb: line 89: 16#80
80
80
80
80: syntax error in expression (error token is "80
80
80
80")
Bus 000 Device 000: ID 05ac
05ac
05ac
05ac
05ac:027a
8103
8262
8514
8233 Apple Inc.
Apple Inc.
Apple Inc.
Apple Inc.
Apple Inc. Apple Internal Keyboard / Trackpad  Serial: FM7919708Q7HYMLAC+MDG
000000000000
000000000000
DJH9225FL7EJ3Y51P
0000000000000000
Bus 000 Device 001: ID 1d6b:PTLP Linux Foundation USB 3.0 Bus
Bus 000 Device 001: ID 1d6b:CITR Linux Foundation USB 3.1 Bus
Bus 000 Device 000: ID 05ac:027a Apple Inc. Apple T2 Bus
shop4mondon
