Circuit Playground Classics---dying in droves
Re: Circuit Playground Classics---dying in droves
by adafruit2 on Tue May 24, 2022 7:32 pm
and you have the circuit playground plugged in?
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 7:37 pm
Drat...It was unplugged
Here ya go
Last login: Tue May 24 16:13:37 on ttys000
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
BSH-STF-DCARTE3:~ don.carter$ lsusb
2022-05-24 16:26:44.068 system_profiler[19080:338617] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-05-24 16:26:44.069 system_profiler[19080:338617] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-05-24 16:26:44.070 system_profiler[19080:338617] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
Bus 020 Device 001: ID 05ac:100f Apple Inc. USB2.0 Hub
Bus 020 Device 014: ID 239a:8011 239a Circuit Playground
Bus 020 Device 002: ID 05ac:1460 Apple Inc. USB-C Digital AV Multiport Adapter  Serial: DLC926700K3G2KQAE
Bus 000 Device 001: ID 05ac:100e Apple Inc. USB3.0 Hub
/usr/local/bin/lsusb: line 89: 16#80
80
80
80
80: syntax error in expression (error token is "80
80
80
80")
Bus 000 Device 000: ID 05ac
05ac
05ac
05ac
05ac:027a
8103
8262
8514
8233 Apple Inc.
Apple Inc.
Apple Inc.
Apple Inc.
Apple Inc. Apple Internal Keyboard / Trackpad  Serial: FM7919708Q7HYMLAC+MDG
000000000000
000000000000
DJH9225FL7EJ3Y51P
0000000000000000
Bus 000 Device 001: ID 1d6b:PTLP Linux Foundation USB 3.0 Bus
Bus 000 Device 001: ID 1d6b:CITR Linux Foundation USB 3.1 Bus
Bus 000 Device 000: ID 05ac:027a Apple Inc. Apple T2 Bus
shop4mondon
by adafruit2 on Tue May 24, 2022 7:40 pm
ok in bootloader mode and plugged into mac, run `lsusb` in terminal
then do the same in non-bootloader mode
paste BOTH outputs and indicate which is which
adafruit2
Site Admin
by shop4mondon on Tue May 24, 2022 7:55 pm
Screen 1
During normal download attempt
Screen 2
After double clicking reset button
Screen 2.png (280.91 KiB) Viewed 488 times
Screen 1 .png (304.29 KiB) Viewed 488 times
shop4mondon
by adafruit2 on Tue May 24, 2022 8:44 pm
ok well its finding it in bootloader mode
now install avrdude:
brew install avrdude
only thing you can try now is to put the board in bootloader mode, then type
avrdude -v -patmega32u4 -cavr109 -P/dev/cu.usbmodem* -b57600
hit return to run it right after you double click and you see the pulsing LED so its definitely in bootloader mode
adafruit2
Site Admin
by shop4mondon on Wed May 25, 2022 3:36 pm
Here's what I get
BSH-STF-DCARTE3:~ don.carter$ avrdude -v -patmega32u4 -cavr109 -P/dev/cu.usbmodem* -b57600
avrdude: Version 7.0
         Copyright (c) Brian Dean, http://www.bdmicro.com/
         Copyright (c) Joerg Wunsch
         System wide configuration file is "/usr/local/Cellar/avrdude/7.0/bin/../etc/avrdude.conf"
         User configuration file is "/Users/don.carter/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem*
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
avrdude: ser_open(): can't open device "/dev/cu.usbmodem*": No such file or directory
avrdude: opening programmer "avr109" on port "/dev/cu.usbmodem*" failed
avrdude done.  Thank you.
shop4mondon
by adafruit2 on Wed May 25, 2022 3:48 pm
try this post again, you should see the device when the CP is plugged in
viewtopic.php?f=48&t=191051&start=45#p925598
adafruit2
Site Admin
by shop4mondon on Tue May 31, 2022 12:43 pm
Howdy
We are still stuck with a bunch of Circuit Playgrounds that won't take sketches.
We have been through dozens of posts suggesting fixes, but no luck.
Is there a point we declare them defective?
Is there a chance that Adafruit would just replace the devices?
shop4mondon
by adafruit2 on Tue May 31, 2022 12:48 pm
the issue is, if we keep replacing them and they keep 'dying in droves', the issue wont resolve itself and we'll be back where we started. we dont know anyone else who can't upload to a CPC - we really think its some mismatch in upload technique - maybe bad timing on trying to upload to the bootloader - but since we are not physically wher eyou are we have to go through our tests step-by-step
can you use CPX instead?
adafruit2
Site Admin
by shop4mondon on Tue May 31, 2022 12:56 pm
Howdy
We tried several strategies ourselves, before we posted to this forum.
We used MacOS, WindowsOS, reinstalling IDE, multiple cables, different sketches, etc.
Then, we have done our best to follow your directions vis this forum and have sent you several lines of code.
We have not received any diagnosis, yet.
But, we have not given up
So, what is CPX ?
shop4mondon
by adafruit2 on Tue May 31, 2022 12:59 pm
right we havent gotten a diagnosis yet because we were waiting for y'all to retry running avrdude with the CPC plugged in.
this is a CPX https://www.adafruit.com/product/3333
adafruit2
Site Admin
by shop4mondon on Tue May 31, 2022 1:14 pm
OK
I guess that I got lost. I'll look through the posts... thought I did everything and sent you code outputs.
So, I'm running the avrdude command in HomeBrew?
BTW:
We already have the Circuit Playground Express devices. They work fine with Python. We were afraid to try Arduino
shop4mondon
by shop4mondon on Tue May 31, 2022 1:26 pm
Hmmmm,
I think I did the avrdude command
Can you check the posts I made on Wed. May 25?
shop4mondon
by adafruit2 on Tue May 31, 2022 3:02 pm
yep see our reply, you should be able to run
make sure the board is plugged in, and you can use ls /dev/cu.usbmodem* from
to verify that the device exists
adafruit2
Site Admin
by shop4mondon on Tue May 31, 2022 3:14 pm
I ran the code in the terminal while the upload was running in arduino
Last login: Tue May 31 08:08:06 on console
shop4mondon
