Hi
So I teach high school art and have built small solar powered robots but I want to know if the 2.8 TFT LCD with Touchscreen breakout board w/Micro 3D Socket IL19341 comes with everything Ill need to make it work??? I notice the LED Kits have a list of additional items would I need anything else? The photos show lots of wires etc. Do I have to buy these separate?? I just dont want to have to order and order
Many thanks
first time with OLED'S
- adafruit_support_carter
Re: first time with OLED'S
The display comes as a breakout board with some header pins. Some of the product photos show it hooked up to a controller board for illustrative purposes, but you will need to supply those items. This photo shows what comes with the product:
https://cdn-shop.adafruit.com/1200x900/1770-03.jpg
Also, OLEDs and LCDs and LEDs are all generally different things. We have displays that are of all three types. May not matter, but just to make sure you know the product you mention is not an OLED display.
Which kits are you referring to here?I notice the LED Kits have a list of additional items
- MMARK
that saves a lot of time...is there anyway to get a list or what would you recommend as far as wanting to set up and use a OLED like the one I mentioned??
Want to make sure we're talking about the same display. Are you referring to this one?
https://www.adafruit.com/products/1770
It's not an OLED. So not sure if you're actually after an OLED, or just curious about that display.
- MMARK
Hi
woops...it did come up under my search for "OLED'S" but that is what I'm looking for..possibly two set-ups for a high school art project.
In addition to the display, you will need a microcontroller to run your program and drive the display. You will also need some wire for connecting the display to the controller.
Here's a general overview of using the display:
https://learn.adafruit.com/adafruit-2-d ... reakout-v2
If you want to use the display with a Pi and Python, there is a library for that as well:
https://learn.adafruit.com/user-space-s ... li9341-2-8
- MMARK
Ok so i would like to do is there anyway you could comprise a list as Im just leaning??? It would really help .....I have a soldering gun but thats about it ...
many thanks
many thanks
You initially mentioned the 2.8 TFT LCD with Touchscreen breakout board w/Micro 3D Socket IL19341. Are you specifically wanting to use that display? Or would another display work? For example, how about combining a Feather:
https://www.adafruit.com/categories/777
with one of the available FeatherWing displays:
https://www.adafruit.com/products/2900
https://www.adafruit.com/products/3315
Asking as this may provide an easier route for you to get started with.
- MMARK
Hi
I don't know the difference but the feather set up looks easier and maybe something a high school student and beginning electronic teacher would understand?? I picked the other screen because it was bigger and for her project would have more impact....
Mark
Mark
- MMARK
Hi again
so she wants to run 2-3 screens if possible and cheaply on the outside of a boot??? Some of the feather products look like they would allow for several small displays to run.....I really liked the blue tooth but could it run pics??? Sorry to ask so many questions
Mark
Mark
I think multiple displays will be a little tricky to get working as a first project. It'd be best to start simple and work your way up from there. By starting with one display you'll learn the basic steps needed to get things working.
Yes. But depends on the display.Some of the feather products look like they would allow for several small displays to run
We have various blue tooth enabled products. Which one are you referring to?I really liked the blue tooth but could it run pics???
I'd say this is generally true.feather set up looks easier and maybe something a high school student and beginning electronic teacher would understand??
- MMARK
ok
so I will take your advice and go with one display say the TFT Feather wing 2.4" can this run off blue tooth or is the SIM better and what other parts would I need to buy ....thanks for your patience
The FeatherWing display is just a display. You need to mate it with a Feather mainboard in order to use it. There are numerous Feather boards that have different capabilities like radio, wifi, bluetooth, etc. Since you've mentioned bluetooth, this seems like the one you'd want:
https://www.adafruit.com/products/2995
As an example of how this would work with the display, here is the display without a Feather board attached:
https://cdn-shop.adafruit.com/1200x900/3315-01.jpg
and here it is with a Feather HUZZAH attached:
https://cdn-shop.adafruit.com/1200x900/3315-04.jpg
- MMARK
ok
Im gettting it now...I like the TFT Feather Wing 2.4 combined with Feather HUZZAH ESP 8266 WIFI, but I noticed with the HUZZAH it offers options would I need of those and can I purchase any other accessories that I would need here....I think Im looking for a shopping list !!!
Just so you know, the HUZZAH has wifi but not bluetooth.
In terms of the header options for the HUZZAH, let me ask this - do you have the ability to solder?
